Dignity
Eclipse Startup Error
Tue Aug 21, 2018 7:11 pm
Hi everyone.
I'm currently having issues with Eclipse on the Raspberry PI 3 B+ (Raspbian). First of all: I never had a PI before and I'm using it for my first time.
However I sadly get an error message when starting Eclipse. It says: "An error has occured. See the log file [...]".
What I did was first to get JDK 9 with the following line:
sudo apt-get install openjdk-9-jdk-headless
And then I installed eclipse with the line:
sudo apt-get install eclipse eclipse-jdt
But sadly I can't start Eclipse. I only get the error. Here is what the logfile says:
!SESSION 2018-08-21 20:55:03.030 -----------------------------------------------
eclipse.buildId=debbuild
java.version=9-Raspbian
java.vendor=Oracle Corporation
BootLoader constants: OS=linux, ARCH=arm, WS=gtk, NL=de_AT
Command-line arguments:  -os linux -ws gtk
!ENTRY org.eclipse.equinox.simpleconfigurator 4 0 2018-08-21 20:55:05.022
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.simpleconfigurator_1.0.301.dist [1]" could not be resolved. Reason: Missing Constraint: Bundle-RequiredExecutionEnvironment: CDC-1.1/Foundation-1.1,J2SE-1.4
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1332)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1316)
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:323)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
	at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.osgi 4 0 2018-08-21 20:55:05.056
!MESSAGE Bundle [email protected]:file:plugins/org.eclipse.equinox.simpleconfigurator_1.0.301.dist.jar was not resolved.
!ENTRY org.eclipse.osgi 2 0 2018-08-21 20:55:05.101
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2018-08-21 20:55:05.101
!SUBENTRY 2 org.eclipse.equinox.simpleconfigurator 2 0 2018-08-21 20:55:05.101
!MESSAGE Missing required capability Require-Capability: osgi.ee; filter="(|(&(osgi.ee=CDC/Foundation)(version=1.1))(&(osgi.ee=JavaSE)(version=1.4)))".
!ENTRY org.eclipse.osgi 2 0 2018-08-21 20:55:05.115
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2018-08-21 20:55:05.115
!MESSAGE Bundle org.eclipse.equinox.simpleconfigurator_1.0.301.dist [1] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.simpleconfigurator 2 0 2018-08-21 20:55:05.115
!ENTRY org.eclipse.osgi 4 0 2018-08-21 20:55:05.118
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:74)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.base/java.lang.reflect.Method.invoke(Method.java:564)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
I hope that someone can help me.
Thanks and have a great day.
Re: Eclipse Startup Error
Wed Aug 22, 2018 9:09 pm
I suspect that if you ever get Eclipse to start up on a Pi it's going to be so slow as to make you wonder why you bothered.
Return to “Java”
