Send SMS with GSM GPRS A6 Module and Java
Posted: Sun Jul 15, 2018 5:48 pm
by cayofontana
Hi there,
I work on academic project where, in some moment, the solution need send SMS for some clients.
Searching on web, I found the example below in Python and it works fine. See it:
import serial
import RPi.GPIO as GPIO
import os, time
GPIO.setmode(GPIO.BOARD)
# Enable Serial Communication
port = serial.Serial("/dev/ttyS0", baudrate=9600, timeout=1)
# Transmitting AT Commands to the Modem
# '\r\n' indicates the Enter key
port.write('AT'+'\r\n')
rcv = port.read(10)
print rcv
time.sleep(1)
port.write('ATE0'+'\r\n')      # Disable the Echo
rcv = port.read(10)
print rcv
time.sleep(1)
port.write('AT+CMGF=1'+'\r\n')  # Select Message format as Text mode
rcv = port.read(10)
print rcv
time.sleep(1)
# Sending a message to a particular Number
port.write('AT+CMGS="+5527999XXXXXX"'+'\r\n')
rcv = port.read(10)
print rcv
time.sleep(1)
port.write('Test'+'\r')  # Message
rcv = port.read(10)
But this academic project was implemented in Java. Then I created a Java code for send SMS but its not working. See it below:
import java.io.IOException;
import java.io.OutputStream;
import java.util.Enumeration;
import java.util.List;
import java.util.ArrayList;
import gnu.io.CommPort;
import gnu.io.CommPortIdentifier;
import gnu.io.PortInUseException;
import gnu.io.SerialPort;
import gnu.io.UnsupportedCommOperationException;
class ComunicacaoMovel
	private static final char enter = 13;
	private static final char ctrlz = 26;
	public ComunicacaoMovel()
	private CommPortIdentifier obterPortaCommSerial()
		Enumeration portasComm = CommPortIdentifier.getPortIdentifiers();
		while (portasComm.hasMoreElements())
			CommPortIdentifier portaComm = (CommPortIdentifier) portasComm.nextElement();
			if (portaComm.getPortType() == CommPortIdentifier.PORT_SERIAL && portaComm.getName().equals("/dev/ttyS0"))
				return (portaComm);
		return (null);
	public void enviarMensagemSMS(String numeroCelular, String mensagem)
		CommPortIdentifier portaComm = obterPortaCommSerial();
		List<String> mensagensSIM = new ArrayList<String>();
		mensagensSIM.add("AT");
		mensagensSIM.add("ATE0");
		mensagensSIM.add("AT+CMGF=1");
		mensagensSIM.add("AT+CMGS=\"+" + numeroCelular + "\"");
		mensagensSIM.add(mensagem);
		try
			SerialPort portaSerial = (SerialPort) portaComm.open("/dev/ttyS0", 2000);
			portaSerial.setSerialPortParams(9600, SerialPort.DATABITS_8, SerialPort.STOPBITS_1, SerialPort.PARITY_NONE);
			OutputStream streamSaida = portaSerial.getOutputStream();
			for (int i = 0; i < mensagensSIM.size(); ++i)
				if (i < (mensagensSIM.size() - 1))
					streamSaida.write((mensagensSIM.get(i) + enter).getBytes());
				else
					streamSaida.write((mensagensSIM.get(i) + ctrlz).getBytes());
				Thread.sleep(1000);
				streamSaida.flush();
			portaSerial.close();
		catch (PortInUseException excecao)
			excecao.printStackTrace();
		catch (IOException excecao)
		catch (UnsupportedCommOperationException excecao)
		catch (InterruptedException excecao)
	public static void main(String[] args)
		ComunicacaoMovel comunicacaoMovel = new ComunicacaoMovel();
		comunicacaoMovel.enviarMensagemSMS("+5527999XXXXXX", "Test");
I suspect that the RXTX library not works correctly, because the SIM900 instructions is the same on both codes (Python and Java).
Anyone can help me?
Thank you!
Re: Send SMS with GSM GPRS A6 Module and Java
Posted: Sun Jul 15, 2018 5:58 pm
by The Traveler
error log?
Posted: Mon Jul 16, 2018 3:52 pm
by cayofontana
Hi The Traveler,
I change the code and now becomes:
	private boolean fim;
		fim = false;
				return (portaComm);
		return (null);
		mensagensSIM.add("AT" + "\r\n");
		mensagensSIM.add("ATE0" + "\r\n");
		mensagensSIM.add("AT+CMGF=1" + "\r\n");
		mensagensSIM.add("AT+CMGS=\"" + numeroCelular + "\"" + "\r\n");
		mensagensSIM.add(mensagem + "\r");
		try
			final Thread threadLeituraStream = new Thread()
				@Override
				public void run()
					try
						final BufferedReader leitor = new BufferedReader(new InputStreamReader(portaSerial.getInputStream()));
						String linha = null;
						while ((linha = leitor.readLine()) != null && !fim)
							System.out.println(linha);
						leitor.close();
					catch (final Exception excecao)
			threadLeituraStream.start();
				streamSaida.write((mensagensSIM.get(i)).getBytes());
				Thread.sleep(1000);
			fim= !fim;
			streamSaida.close();
Here the output (without errors):
OK
OK
OK
... and the console stay lock with this program. It isn't return to console command prompt and I don't receive the SMS.
But curiously, the Python code send SMS correctly.
What do you think?
Thank you!
