abhi143
Blinking LED on Raspberry Pi using Java
Mon Jan 01, 2018 2:22 pm
I want to blink led on Raspberry Pi using Java. I am following this link http://www.admfactory.com/blinking-led- ... sing-java/ There is information about the Pi4J library. I understand I have to install Pi4J library.
I think only Pi4J library is not enough to to write and compile java program. there will be java IDE to write and compile program. I don't find any information about java IDE in link. Can someone tell me which one java IDE is being use in the given link ?
Re: Blinking LED on Raspberry Pi using Java
Mon Jan 01, 2018 2:42 pm
You don't need an IDE to write and compile a Java program. Or any other language for that matter. Any old editor will do.
abhi143
Mon Jan 01, 2018 4:42 pm
I have written and save java program using nano editor now how to run program on Pi.
Mon Jan 01, 2018 5:03 pm
nano /home/pi/java/programname.java
public class programname
  public static void main(String[] args)
    System.out.println("Hello Java World");
cd ~/java
javac programname.java
java programname
abhi143
Mon Jan 01, 2018 5:38 pm
I am getting some errors I think Pi4J library has not installed correctly
I was running following command
$ curl -s get.pi4j.com | sudo bash
pi@raspberrypi:~ $ javac led.java
led.java:1: error: package com.pi4j.io.gpio does not exist
import com.pi4j.io.gpio.GpioController;
led.java:2: error: package com.pi4j.io does not exist
import com.pi4j.io.GpioFactory;
led.java:3: error: package com.pi4j.io.gpio does not exist
import com.pi4j.io.gpio.GpioPinDigitalOutput;
led.java:4: error: package com.pi4j.io.gpio does not exist
import com.pi4j.io.gpio.RaspiPin;
led.java:10: error: cannot find symbol
final GpioController gpio = GpioFactory.getInstance();
symbol: class GpioController
symbol: variable GpioFactory
led.java:12: error: cannot find symbol
Mon Jan 01, 2018 6:05 pm
Take a look at /opt/pi4j/examples/build which shows you how to build a pi4j Java program.
javac -classpath .:classes:/opt/pi4j/lib/'*' -d . /home/pi/java/pi4jprogram.java
Then you run it with
WIRINGPI_GPIOMEM=1 java -classpath /opt/pi4j/lib/pi4j-core.jar:. pi4jprogram
abhi143
Mon Jan 15, 2018 3:03 pm
What is meaning of this error
pi@raspberrypi:~ $ sudo nano BlinkingLed.java
pi@raspberrypi:~ $ sudo javac BlinkingLed.java -classpath .:/opt/pi4j/lib/'*'
pi@raspberrypi:~ $ sudo java -cp .:/opt/pi4j/lib/'*' BlinkingLed
Unable to determine hardware version. I see: Hardware : BCM2835
- expecting BCM2708 or BCM2709.
If this is a genuine Raspberry Pi then please report this
to projects@drogon.net. If this is not a Raspberry Pi then you
are on your own as wiringPi is designed to support the
Raspberry Pi ONLY.
Mon Jan 15, 2018 5:28 pm
Return to “Java”
