jonny789
JavaFX: Cannot open display problem
Sat Dec 23, 2017 8:56 am
I want to create some GUI for Raspberry Pi 1 B. So I found JavaFX is best for my purpose. Installed it following this tutorial :
http://www.oracle.com/webfolder/technet ... rryfx.html
Created Basic JavaFX Application-Hello World. Set GPU memory to 128M.
Copied BasicFX.jar to pi and ran using ::
sudo java -jar BasicFX.jar
. But it showed this
error ::  error: could not find or load main class java
After searching for solution , I found this : stackoverflow.com/questions/38359076/h ... berry-pi-3 . But Running it again showing this error now ::
Cannot open display
Exception in Application start method
java.lang.reflect.InvocationTargetException
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:498)
        at com.sun.javafx.application.LauncherImpl.launchApplicationWithArgs(LauncherImpl.java:389)
        at com.sun.javafx.application.LauncherImpl.launchApplication(LauncherImpl.java:328)
        at sun.launcher.LauncherHelper$FXHelper.main(LauncherHelper.java:767)
Caused by: java.lang.RuntimeException: Exception in Application start method
        at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:917)
        at com.sun.javafx.application.LauncherImpl.lambda$launchApplication$156(LauncherImpl.java:182)
        at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.ExceptionInInitializerError
        at javafx.scene.Node.reapplyCss(Node.java:8983)
        at javafx.scene.Node.impl_reapplyCSS(Node.java:8946)
        at javafx.scene.Node.invalidatedScenes(Node.java:854)
        at javafx.scene.Node.setScenes(Node.java:919)
        at javafx.scene.Scene$9.invalidated(Scene.java:1119)
        at javafx.beans.property.ObjectPropertyBase.markInvalid(ObjectPropertyBase.java:111)
        at javafx.beans.property.ObjectPropertyBase.set(ObjectPropertyBase.java:146)
        at javafx.scene.Scene.setRoot(Scene.java:1072)
        at javafx.scene.Scene.<init>(Scene.java:347)
        at javafx.scene.Scene.<init>(Scene.java:223)
        at basicfx.BasicFX.start(BasicFX.java:37)
        at com.sun.javafx.application.LauncherImpl.lambda$launchApplication1$163(LauncherImpl.java:863)
        at com.sun.javafx.application.PlatformImpl.lambda$runAndWait$176(PlatformImpl.java:326)
        at com.sun.javafx.application.PlatformImpl.lambda$null$174(PlatformImpl.java:295)
        at java.security.AccessController.doPrivileged(Native Method)
        at com.sun.javafx.application.PlatformImpl.lambda$runLater$175(PlatformImpl.java:294)
        at com.sun.glass.ui.monocle.RunnableProcessor.runLoop(RunnableProcessor.java:93)
        at com.sun.glass.ui.monocle.RunnableProcessor.run(RunnableProcessor.java:52)
        ... 1 more
Caused by: java.lang.NullPointerException
        at com.sun.javafx.font.PrismFontLoader.loadFont(PrismFontLoader.java:196)
        at javafx.scene.text.Font.<init>(Font.java:319)
        at javafx.scene.text.Font.getDefault(Font.java:86)
        at javafx.scene.CssStyleHelper.<clinit>(CssStyleHelper.java:1528)
        ... 19 more
Exception running application basicfx.BasicFX
Re: JavaFX: Cannot open display problem
Sat Dec 23, 2017 9:04 am
1. DON'T use sudo, it shouldn't need sudo. Stop running everything as root.
2. Set the display variable see if that helps.
DISPLAY=:0 java -jar BasicFX.jar
Note:Having anything remotely humorous in your signature is completely banned on this forum.
jonny789
Sat Dec 23, 2017 9:26 am
Actually runnning without sudo shows these errors ::
Udev: Failed to write to /sys/class/input/mice/uevent
      Check that you have permission to access input devices
Udev: Failed to write to /sys/class/input/input1/uevent
Udev: Failed to write to /sys/class/input/event1/uevent
Udev: Failed to write to /sys/class/input/input2/uevent
Udev: Failed to write to /sys/class/input/event2/uevent
Udev: Failed to write to /sys/class/input/input0/uevent
Udev: Failed to write to /sys/class/input/event0/uevent
Errors are still the same.
Do I need to do any setting to set output to hdmi ? Anything inside /boot/config.txt ?
Sat Dec 23, 2017 9:58 am
Is the GUI running? Are you running your Java program in a LXTerminal window?
jonny789
Sat Dec 23, 2017 11:54 am
There is no GUI. I have installed Raspbian Stretch Lite.
Sat Dec 23, 2017 3:07 pm
You can't run Java graphics without Xwindows.
jonny789
Sat Dec 23, 2017 3:41 pm
Which package or program do I need to install ?
Sat Dec 23, 2017 3:45 pm
X11 Xwindows.
sudo apt update
sudo apt install raspberrypi-ui-mods
should pull in what you need.
jonny789
Sat Dec 23, 2017 7:23 pm
X11 Xwindows.
sudo apt update
Thanks. It is working now. :)
raspberrypi-ui-mods is quite big (455 MB) for my 2GB card. So there is not enough space to install it. Therefore, I installed just minimal packages (taking about 120MB space) to run JavaFX.
sudo apt install xorg  libgtk2.0-0
But, I still need to run with sudo, for GUI apps needing mouse and keyboard.
While running , it still shows these messages ::
Cannot open display
Cannot create resource
But it works fine. ;)
Bhaumik156
Fri Feb 02, 2018 10:08 am
I want to run a javafx software . It is giving me the same errors as mentioned above. I tried the steps above but no results and it is showing the same error cannnot open display and cannot create resource . please help
Bhaumik156
Fri Feb 02, 2018 10:27 am
still error is persisting with my application and it is not running
pleasse help
B.Goode
Fri Feb 02, 2018 10:35 am
pleasse help
Advice in these forums is provided by unpaid volunteers. Maybe noone with the necessary interest, skills or knowledge has logged in during the 19 minutes since you first raised this query.
To improve your chances of a helpful response, indicate what Operating System is running on your RPi, and how its graphical output is configured : a directly connected display with a standard Raspbian Pi Foundation desktop, or a network accessed 'headless' installation?
Which of the steps already suggested to previous posters have you tried, and with what results?
texy
Fri Feb 02, 2018 10:57 am
pleasse help
What B.Goode said - please be patient.
ripcore
Sun Feb 04, 2018 12:11 pm
What is your OS on pi?
Do you use LCD screen or Touch Screen?
JLamberti
Fri Apr 13, 2018 1:08 pm
Hi, everybody.
I'm new on Raspberry development. I have the very same problem. The application runs fine, i figure out that if i move the mouse the cursor position on the controls and if i clickit the application runs fine.
For solving the access to the input devices issues i followed this link: https://alexconesa.wordpress.com/2017/0 ... pberry-pi/
But the cursor don't appears.
The thing is this:
I've tried NOOBS and Raspbian with the same jar file, with the same results.
I installed differents JDK8 releases, with the last Gluom JavaFX.
I'm working on a IoT projecr using the RPI. Any help wil be appretiated.
Hope the lilnk was usefull
Return to “Java”
