I have been trying to install thingsboard on my Rpi2 B+ model for which it needs a javaupdate which i have updated to 1.8.0_151 but i am still getting the following error when I was trying to unpack thingsboard installation setup.
pi@raspberrypi ~ $ sudo dpkg -i thingsboard-1.3.1.deb
(Reading database ... 77120 files and directories currently installed.)
Preparing to replace thingsboard 1.3.1-1 (using thingsboard-1.3.1.deb) ...
Unpacking replacement thingsboard ...
update-rc.d: using dependency based boot sequencing
dpkg: dependency problems prevent configuration of thingsboard:
thingsboard depends on openjdk-8-jre | java8-runtime | oracle-java8-installer | openjdk-8-jre-headless; however:
Package openjdk-8-jre is not installed.
Package java8-runtime is not installed.
Package oracle-java8-installer is not installed.
Package openjdk-8-jre-headless is not installed.
dpkg: error processing thingsboard (--install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
thingsboard
I tried to install java8jdk but the result was following:
pi@raspberrypi ~ $ sudo apt-get install oracle-java8-installer
Reading package lists... Done
Building dependency tree
Package oracle-java8-installer is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'oracle-java8-installer' has no installation candidate
please help
Re: Java error in Thingsboard installation
Try installing openjdk-8-jre
venkyskar wrote: ↑Mon Nov 20, 2017 2:26 pmHello,
thingsboard
please help
https://thingsboard.io/docs/user-guide/install/rpi/
OpenJDK
sudo apt-get update
sudo apt-get install openjdk-8-jdk
I have already installed java jre and jdk but still I am getting that error while unpacking Thingsboard. Even I have tried your suggestion this is the result I got:DirkS wrote: ↑Mon Nov 20, 2017 2:34 pmThis means it needs one of these.Code: Select all
pi@raspberrypi ~ $ sudo apt-get install openjdk-8-jre
Package openjdk-8-jre is not available, but is referred to by another package.
E: Package 'openjdk-8-jre' has no installation candidate
pi@raspberrypi ~ $
venkyskar wrote: ↑Tue Nov 21, 2017 11:48 amI have already installed java jre and jdk but still I am getting that error while unpacking Thingsboard. Even I have tried your suggestion this is the result I got:DirkS wrote: ↑Mon Nov 20, 2017 2:34 pmThis means it needs one of these.Code: Select all
pi@raspberrypi ~ $
Did you try my suggestion, which was assuming you are running the current Raspbian Stretch ??
Did you run 'sudo apt update' before trying to install the package?
Which OS (distro + version) do you run on?
@DirkS
Yes i did that before instaling
@fruitoftheloom: No my rasbian is wheezy not at all a latest streach.
Raspbian Wheezy was end of life 2015, maybe it is time to use Raspbian Stretch and newer packages ??
