venkyskar
Java error in Thingsboard installation
Mon Nov 20, 2017 2:26 pm
I have been trying to install thingsboard on my Rpi2 B+ model for which it needs a javaupdate which i have updated to 1.8.0_151 but i am still getting the following error when I was trying to unpack thingsboard installation setup.
pi@raspberrypi ~ $ sudo dpkg -i thingsboard-1.3.1.deb
(Reading database ... 77120 files and directories currently installed.)
Preparing to replace thingsboard 1.3.1-1 (using thingsboard-1.3.1.deb) ...
Unpacking replacement thingsboard ...
update-rc.d: using dependency based boot sequencing
dpkg: dependency problems prevent configuration of thingsboard:
thingsboard depends on openjdk-8-jre | java8-runtime | oracle-java8-installer | openjdk-8-jre-headless; however:
Package openjdk-8-jre is not installed.
Package java8-runtime is not installed.
Package oracle-java8-installer is not installed.
Package openjdk-8-jre-headless is not installed.
dpkg: error processing thingsboard (--install):
dependency problems - leaving unconfigured
thingsboard
I tried to install java8jdk but the result was following:
pi@raspberrypi ~ $ sudo apt-get install oracle-java8-installer
Reading package lists... Done
Building dependency tree
Package oracle-java8-installer is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'oracle-java8-installer' has no installation candidate
please help
DirkS
Re: Java error in Thingsboard installation
Mon Nov 20, 2017 2:34 pm
This means it needs one of these.
Try installing openjdk-8-jre
Mon Nov 20, 2017 2:38 pm
thingsboard
please help
https://thingsboard.io/docs/user-guide/install/rpi/
OpenJDK
sudo apt-get update
sudo apt-get install openjdk-8-jdk
The information is out there....you just have to let it in.
venkyskar
Tue Nov 21, 2017 11:48 am
I have already installed java jre and jdk but still I am getting that error while unpacking Thingsboard. Even I have tried your suggestion this is the result I got:
pi@raspberrypi ~ $ sudo apt-get install openjdk-8-jre
Package openjdk-8-jre is not available, but is referred to by another package.
E: Package 'openjdk-8-jre' has no installation candidate
pi@raspberrypi ~ $
Tue Nov 21, 2017 12:27 pm
pi@raspberrypi ~ $
Did you try my suggestion, which was assuming you are running the current Raspbian Stretch ??
DirkS
Tue Nov 21, 2017 12:30 pm
Did you run 'sudo apt update' before trying to install the package?
Which OS (distro + version) do you run on?
venkyskar
Wed Nov 22, 2017 11:21 am
@DirkS
Yes i did that before instaling
@fruitoftheloom: No my rasbian is wheezy not at all a latest streach.
Wed Nov 22, 2017 11:36 am
@DirkS
Raspbian Wheezy was end of life 2015, maybe it is time to use Raspbian Stretch and newer packages ??
Return to “Java”
