mahendra28
About How to Create Executable file in Raspberry Pi
Wed Nov 01, 2017 4:33 am
Hi All,
I just want know How to create executable file in raspberry platform.actually i am creating Java Swing application using Pi4j API
and also i am creating jar file of that all classes but it nt working for me.
so guyz please give me suggestion
clicky
Re: About How to Create Executable file in Raspberry Pi
Thu Nov 02, 2017 8:44 am
Try searching for creation of 'executable' jar. Depending what build mechanism you are using there are different ways to do so. In Eclipse, for instance, you can select 'Export' -> 'Executable Jar' and select main class. If you are doing things 'properly' and have build set up (maven for instance) then search for your build mechanism how to do it (maven plugin, grails variable, etc).
Such jar file, then, can be 'executed' on RPi with
java -jar myjar.jar
addeswe
Tue Nov 07, 2017 3:32 pm
What you can do is create a shellscript with the following code:
#!/bin/sh
MYSELF=`which "$0" 2>/dev/null`
[ $? -gt 0 -a -f "$0" ] && MYSELF="./$0"
java=java
if test -n "$JAVA_HOME"; then
    java="$JAVA_HOME/bin/java"
fi
exec "$java" $java_args -jar $MYSELF "[email protected]"
exit 1
After that, just cat the jar-file into the shellscript with >> (so you append it). Then all you need to do is make the shell script executeable with chmod +x and run it.
“Knock, knock.” - “Who’s there?” - very long pause…. - “Java.”
If a python knocks on your door and says “Hi, I’m a vacuum cleaner!” it’s not true. That’s a python.
clicky
Wed Nov 08, 2017 9:57 am
Brilliant! Do you have any references *why* it works?
Also - maybe calling "java_args" as "JAVA_ARGS" would make more sense but otherwise it is just brilliant!
Return to “Java”
