cpunk
Code sample: rolling rainbow on APA102 LEDs from Java
Sat Oct 28, 2017 9:44 pm
Since this bit took me a few hours to code, I thought I'd try to save time for others in case they try similar ventures. :)
Basically, I got some APA102 LEDs and needed to implement blinking lights and a continuously rolling rainbow with them. The program needed to be in Java, as the rest of my system is coded in Java. As a dependency, it used the PI4J library and of course the SPI pins of Raspberry Pi (specifically MOSI and SCLK).
The result:
Photo of LEDs in action :)
This is the class that drives LEDs:
package cc.headless;
import com.pi4j.io.spi.SpiChannel;
import com.pi4j.io.spi.SpiDevice;
import com.pi4j.io.spi.SpiFactory;
public class LedController extends Thread {
	// How many APA102 pixels we have
	private static final int PIXELS = 20;
    // Pi4J SPI device
    public static SpiDevice spi = null;
    // Stop semaphore.
    public volatile boolean stop = false;
    // Current values
    byte rainbowSegment = 0;
	byte r = 0;
	byte g = 0;
	byte b = 0;
	// Backup values stored at step X into loop, to enable smooth stepping
	byte bR = 0;
	byte bG = 0;
	byte bB = 0;
	byte bSegment = 0;
	// Start each sending of pixels with an "initialize" command
    byte init[] = new byte[] {
            (byte) 0b00000000, (byte) 0b00000000, (byte) 0b00000000, (byte) 0b00000000,
    // Some hard coded colors for testing
    byte red[] = new byte[] {
            (byte) 0b11111111, (byte) 0b00000000, (byte) 0b00000000, (byte) 0b11111111,
    byte green[] = new byte[] {
            (byte) 0b11111111, (byte) 0b00000000, (byte) 0b11111111, (byte) 0b00000000,
    byte blue[] = new byte[] {
            (byte) 0b11111111, (byte) 0b11111111, (byte) 0b00000000, (byte) 0b00000000,
    byte black[] = new byte[] {
            (byte) 0b11111111, (byte) 0b00000000, (byte) 0b00000000, (byte) 0b00000000,
    byte white[] = new byte[] {
            (byte) 0b11111111, (byte) 0b11111111, (byte) 0b11111111, (byte) 0b11111111,
    public LedController() {
        try {
        	log("Getting SPI instance...");
        	spi = SpiFactory.getInstance(SpiChannel.CS0,
        			SpiDevice.DEFAULT_SPI_SPEED, // According to Pi4J: default spi speed 1 MHz
        			SpiDevice.DEFAULT_SPI_MODE); // According to Pi4J: default spi mode 0
        } catch (Exception e) {
        	log("Failed getting SPI instance.");
        	e.printStackTrace();
    private void log(String msg) {
    	System.out.println(msg);
    private void turn(byte[] color, int pixels, int sleep) {
    	try {
    		spi.write(init);
    		if (sleep > 0) Thread.sleep(sleep);
    		for (int i = 0; i < pixels; i++) {
    			spi.write(color);
    private void blink(byte[] color, int times, int delay) {
    	try {
    		for (int i = 0; i < times; i++) {
    			turn(black, 20, 0);
    			Thread.sleep(delay);
    			turn(color, 20, 0);
    private void rainbowNext(int drawFor) {
    	byte backup = 1;
    	byte step = 4;
    	byte max = 0b00011111;
    	byte min = 0b00000000;
    	try { spi.write(init); } catch (Exception e) { e.printStackTrace(); }
    	// At start of run, restore values from backups
    	r = bR;
    	g = bG;
    	b = bB;
    	rainbowSegment = bSegment;
    	for (int i = 0; i < drawFor; i++) {
    		// At iteration BACKUP, store backups of R,G,B.
    		if (i == backup) {
    			bR = r;
    			bG = g;
    			bB = b;
    			bSegment = rainbowSegment;
    		if (rainbowSegment == 0) {
    			r = (byte) max;
    			g = (byte) Math.min(max,(g + step));
    			b = (byte) min;
    			if (g >= max) {
    				rainbowSegment = 1;
    		if (rainbowSegment == 1) {
    			r = (byte) Math.max(min, (r - step));
    			g = (byte) max;
    			b = (byte) min;
    			if (r <= min) {
    				rainbowSegment = 2;
    		if (rainbowSegment == 2) {
    			r = (byte) min;
    			g = (byte) max;
    			b = (byte) Math.min(max,(b + step));
    			if (b >= max) {
    				rainbowSegment = 3;
    		if (rainbowSegment == 3) {
    			r = (byte) min;
    			g = (byte) Math.max(min, (g - step));
    			b = (byte) max;
    			if (g <= min) {
    				rainbowSegment = 4;
    		if (rainbowSegment == 4) {
    			r = (byte) Math.min(max,(r + step));
    			g = (byte) min;
    			b = (byte) max;
    			if (r >= max) {
    				rainbowSegment = 5;
    		if (rainbowSegment == 5) {
    			r = (byte) max;
    			g = (byte) min;
    			b = (byte) Math.max(min,b - step);
    			if (b <= min) {
    				rainbowSegment = 0;
   			// log("S: " + rainbowSegment + " r=" + r + ",  g=" + g + ",  b=" + b);
   			byte[] bb = new byte[4];
   			bb[0] = (byte) 0b11111111;
   			bb[1] = b;
   			bb[2] = g;
   			bb[3] = r;
   			try { spi.write(bb); } catch (Exception e) { e.printStackTrace(); }
    	// log("================================================");
    @Override
    public void run() {
    	// Blink each RGB color and also white 3 times.
    	blink(red,3,500);
    	blink(green,3,500);
    	blink(blue,3,500);
    	blink(white,3,500);
    	try {
    		// Start a continuously rolling rainbow, stepping at 100 ms intervals.
    		while (!stop) {
    			rainbowNext(PIXELS);
   				Thread.sleep(100);
        	log("Fatal error in LED controller.\n" + e);
        	System.exit(1);
        } finally {
This is how I call it:
try {
        	log("Creating and starting LED controller thread.");
            led = new LedController();
        	led.start();
            log("Failed creating/starting LED controller thread.\n" + e);
            System.exit(1);
mattlewis
Re: Code sample: rolling rainbow on APA102 LEDs from Java
Sun Oct 29, 2017 1:22 pm
Very nice. I wrote a Java wrapper for the rpi_ws281x library, here: https://github.com/mattjlewis/diozero/t ... s281x-java
I’ve been thinking for sometime that I should see if I could implement a pure Java solution given I’d read you can control them via SPI.
Thanks for sharing your code.
http://www.diozero.com/
Jamie1990
Mon Jun 04, 2018 8:27 am
now i have to use APA107 LED to replace APA102, as the APA102 LED has stopped producing, no store sell it.......
Jamie1990
Mon Jun 04, 2018 8:46 am
Hi, Sir
hope you are well.
Now nobody can make APA102/APA102C Pixel LED, if you still need APA102/APA102C LED, you have to consider APA107 LED, this is the upgrade of APA102 LED, all is same, IC and LED all made in China.
APA107 datasheet
http://www.newstar-ledstrip.com/product ... 954307.pdf
Any problems, welcome to contact us
Newstar
Return to “Java”
