narraccino
ALSA - AudioSystem.isLineSupported FAILS with USB MIC
Wed Oct 11, 2017 3:28 pm
i'm using an USB MIC on a Raspberry and i'm developing with the JAVA SOUND API
but the Line is Not Supported, why?
I've executed this code on a normal PC with Linux and it works (the Line is supported and the Mic works)
What is missing? how can is get Line Supported?
the cose is this:
import javax.sound.sampled.AudioFormat;
import javax.sound.sampled.AudioSystem;
import javax.sound.sampled.DataLine;
import javax.sound.sampled.LineUnavailableException;
import javax.sound.sampled.Mixer;
import javax.sound.sampled.Port;
import javax.sound.sampled.TargetDataLine;
public class TestAudio {
	public static void main(String[] args) throws LineUnavailableException {
		Mixer.Info minfo[] = AudioSystem.getMixerInfo();
		for (Mixer.Info minfo1 : minfo) {
			System.out.println(minfo1);
		if (AudioSystem.isLineSupported(Port.Info.MICROPHONE)) {
			System.out.println("++ LINE IS SUPPORTED ++");
		} else {
			System.out.println("Line is NOT supported");
The output is this:
ALSA [default], version 4.9.54-v7+
ALSA [plughw:0,0], version 4.9.54-v7+
ALSA [plughw:0,1], version 4.9.54-v7+
Device [plughw:1,0], version 4.9.54-v7+
Port ALSA [hw:0], version 4.9.54-v7+
Port Device [hw:1], version 4.9.54-v7+
jbeale
Re: ALSA - AudioSystem.isLineSupported FAILS with USB MIC
Fri Oct 13, 2017 5:49 pm
Sorry I can't assist, I have never tried developing in Java on any platform. The only things I've done on RPi like this is recording audio from a USB webcam with 'arecord' and also separately with 'ffmpeg' as described here: https://lb.raspberrypi.org/forums/viewt ... 0#p1006200
If you can get 'arecord' to work from the command line, that would demonstrate that the hardware and the Linux audio driver is working, and it is a higher-level issue with whatever tools you are using.
knute
Fri Oct 13, 2017 7:19 pm
I'm not sure why that doesn't work but I've never been able to get a line from a Port that way (on Windows or Linux). If you want the microphone just get a TargetDataLine with the appropriate AudioFormat and it will be the microphone.
Please see my Intercom program at knutejohnson.com/pi for some code examples.
Return to “Java”
