escondax
Java Core dump failure
Wed Oct 04, 2017 7:42 am
Hello everyone I get this error when ı tried to run my java program.I don't want to change jdk with any version cause of compatibility for Javafx.
The error is available below.I just want to enable core dump as informed which is available in error (ulimit -c unlimited) before initial of the program.How can i do that?
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0x00000000, pid=1182, tid=1663788144
# JRE version: Java(TM) SE Runtime Environment (8.0-b132) (build 1.8.0-b132)
# Java VM: Java HotSpot(TM) Client VM (25.0-b70 mixed mode linux-arm )
# Problematic frame:
# C  0x00000000
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /root/hs_err_pid1182.log
# If you would like to submit a bug report, please visit:
#   http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Aborted
escondax
Re: Java Core dump failure
Wed Oct 04, 2017 8:26 am
I am now running ulimit -c unlimited function before my program and installed new version of java.But I still get same error.
sourav790
Fri Aug 14, 2020 10:40 am
Getting the same error while running JavaFX application using the command sudo java -jar FileName.jar.
Please any one have any solution or suggestion please do forward .
knute
Sat Aug 15, 2020 2:28 am
I had the same problem and it appears to be something with the amount of video memory. Try increasing it and see if that fixes the problem.
Return to “Java”
