jorgepetroni
How to read and write in usb rs232?
Fri Aug 04, 2017 3:50 pm
Hello, I need your help, I have pi3 b with a display 3.5 and usb rs232. I need information how to handle usb rs232 in java. thanks.
JosAH
Re: How to read and write in usb rs232?
Sun Aug 06, 2017 9:26 am
That is quite easy in Java: simply open device /dev/ttyUSB0 as if it were a file; if you read from it, your program is reading from whatever is located on the other side of the (serial) bus; if you write to it, the data will be written to that other device.
kind regards,
Jos
nadgetastic
Fri Sep 15, 2017 5:54 pm
Or use a general purpose library like http://fazecast.github.io/jSerialComm/
Return to “Java”
Who is online
Users browsing this forum: No registered users and 6 guests
