andrew.grimm3
Node Red Function for Array (Javascript)
Tue Jul 25, 2017 3:57 pm
I'm experimenting around in node-red (graphical interface for IoT) and I am trying to use an SQL select statement inside of a function to return the maximum temperature present in a MySQL db table. The select function is working correct as my msg.payload debug node is displaying the result.
However, what I want to do is just display the number reset and not the whole object. I assume I need another function node but not exactly sure what to do.
Example: My debug node which is using msg.payload is displaying {"MAX":"99"}. What I really want the msg.payload to contain is just 99.
Thanks,
Andrew
topguy
Re: Node Red Function for Array (Javascript)
Wed Jul 26, 2017 10:47 am
Change the "Value format" of the "text" node to
{{ msg.payload["MIN"] }}
Return to “Java”
Who is online
Users browsing this forum: No registered users and 5 guests
