Jach00
Problem with gnu.io.RXTXCommDriver
Tue Jul 11, 2017 11:34 am
I have raspberry pi3 with raspbian and java 8 jdk installed.
I have program which uses https://github.com/NeuronRobotics/nrjavaserial . It works perfectly on Windows, but when i tried to run it on raspberry I got:
java.lang.UnsatisfiedLinkError: gnu.io.RXTXCommDriver.nativeGetVersion()Ljava/lang/String;
thrown while loading gnu.io.RXTXCommDriver
java.lang.NoClassDefFoundError: Could not initialize class gnu.io.RXTXCommDriver thrown while loading gnu.io.RXTXCommDriver
I installed rxtx by
sudo apt-get install librxtx-java
like it was shown here: viewtopic.php?f=81&t=69414
App is started by this command:
java -Djava.library.path=/usr/lib/jni -cp /usr/share/java/RXTXcomm.jar:. -jar appName.jar
nadgetastic
Re: Problem with gnu.io.RXTXCommDriver
Fri Sep 15, 2017 5:56 pm
Don't use the RxTx library, it's outdated, unsupported and problematic to install.
Use http://fazecast.github.io/jSerialComm/ - same features without all the hassle of manually installing native binaries
cpunk
Thu Nov 02, 2017 10:58 pm
Another RxTx user here, and thanks for the tip. Will try the alternative in my next project. :)
My personal experience is that it works better with OpenJDK JVM, as opposed the Oracle JVM. Probably another of those library loading issues. Most likely quite solvable, but needs lots of trying.
cpunk
Wed Nov 08, 2017 4:09 pm
So I tested them, with as much time I had.
I needed to get a Scanse Sweep rotating lidar working, and get it working soon...
...I wrote the initial code for jSerialComm and it worked on my laptop. On a Pi 0W unit, it mysteriously did nothing, with no error messages whatsoever. The port opened, but no commands seemed to reach the lidar unit.
So in the end, I turned to Pi4j and got it working. Pi4j apparently supports all kinds of ports, not only GIPO and SPI, but also serial. :)
Return to “Java”
Who is online
Users browsing this forum: No registered users and 5 guests
