I have raspberry pi3 with raspbian and java 8 jdk installed.
I have program which uses https://github.com/NeuronRobotics/nrjavaserial . It works perfectly on Windows, but when i tried to run it on raspberry I got:
java.lang.UnsatisfiedLinkError: gnu.io.RXTXCommDriver.nativeGetVersion()Ljava/lang/String;
thrown while loading gnu.io.RXTXCommDriver
java.lang.NoClassDefFoundError: Could not initialize class gnu.io.RXTXCommDriver thrown while loading gnu.io.RXTXCommDriver
sudo apt-get install librxtx-javaApp is started by this command:
java -Djava.library.path=/usr/lib/jni -cp /usr/share/java/RXTXcomm.jar:. -jar appName.jar
