lizardman1499
Java Pi4J LED Strip Strobing/Flashing
Mon Jul 03, 2017 8:11 pm
This is my first post on here so please excuse an improper format. I have recently begun to work on a program to control an RGBW LED strip using Java. I have used the PI4J library and had more success that I expected until now. It seems when I turn on colors that incorporate an R, G, and B value, the led strip begins to strobe very fast, however, the strip works completely fine when just the R, G, B, or W LEDs are turned on. I have done countless hours of research on PWM frequency to find a solution to no avail. I anyone could point me in some direction that would be much appreciated.
Cheers,
Aaron
Below is the "Light Controller" Class I have written and been using to control the LEDs.
import com.pi4j.wiringpi.Gpio;
import com.pi4j.wiringpi.SoftPwm;
public class LightController {
	private final int RANGE = 100;
	private final int RED_PIN;
	private final int GREEN_PIN;
	private final int BLUE_PIN;
	private final int WHITE_PIN;
	private boolean lightsOn;
	private int R_VAL;
	private int G_VAL;
	private int B_VAL;
	private int W_VAL;
	public LightController(int red, int green, int blue, int white) {
		lightsOn = false;
		RED_PIN = red;
		GREEN_PIN = green;
		BLUE_PIN = blue;
		WHITE_PIN = white;
		try {
			Gpio.wiringPiSetup();
			SoftPwm.softPwmCreate(RED_PIN, 0, RANGE);
			SoftPwm.softPwmCreate(GREEN_PIN, 0, RANGE);
			SoftPwm.softPwmCreate(BLUE_PIN, 0, RANGE);
			SoftPwm.softPwmCreate(WHITE_PIN, 0, RANGE);
		} catch (IllegalArgumentException e) {
			System.out.println("Unsupported System...");
	//Converts number for pin output
	private int convertNumForPin(int num, int inMin, int inMax, int outMin, int outMax) {
		return (num - inMin) * (outMax - outMin) / (inMax - inMin) + outMin;
	public void setLedColor(int r, int g, int b) {
		R_VAL = convertNumForPin(r, 0, 255, 0, RANGE);
		G_VAL = convertNumForPin(g, 0, 255, 0, RANGE);
		B_VAL = convertNumForPin(b, 0, 255, 0, RANGE);
		if (R_VAL == G_VAL && G_VAL == B_VAL && B_VAL == R_VAL) { //If R, G, and B are equal, turn on White LED
			W_VAL = R_VAL;
			R_VAL = 0;
			G_VAL = 0;
			B_VAL = 0;
		} else {
			W_VAL = 0;
		if (lightsOn) updateLights();
	public void updateLights() { //Change the pin value to the new color
		SoftPwm.softPwmWrite(RED_PIN, R_VAL);
		SoftPwm.softPwmWrite(GREEN_PIN, G_VAL);
		SoftPwm.softPwmWrite(BLUE_PIN, B_VAL);
		SoftPwm.softPwmWrite(WHITE_PIN, W_VAL);
	public void lightsOn(int r, int g, int b) {
		lightsOn = true;
		setLedColor(r, g, b);
	public void lightsOff() {
		setLedColor(0, 0, 0);
		lightsOn = false;
	public boolean lightsOn() {
		return lightsOn;
Re: Java Pi4J LED Strip Strobing/Flashing
Tue Jul 04, 2017 6:42 am
You've got no delays in your code, so it will spin round as fast as the system can despatch it. Try using
            //Pause for 0.1 seconds
            Thread.sleep(100);
between each state change for a gpio pin.
This is a doctor free zone.
lizardman1499
Wed Jul 05, 2017 4:51 am
DougieLawson wrote:You've got no delays in your code, so it will spin round as fast as the system can despatch it. Try using
            Thread.sleep(100);
I changed my updateLights function to the following with no success. I may have misunderstood so feel free to correct me if I'm wrong.
		try {
			Thread.sleep(100);
			Thread.sleep(100);
			Thread.sleep(100);
			Thread.sleep(100);
		} catch (InterruptedException e) {
			e.printStackTrace();
Wed Jul 05, 2017 5:39 am
Try increasing the length of that delay.
lizardman1499
Wed Jul 05, 2017 6:56 am
DougieLawson wrote:Try increasing the length of that delay.
Still no luck. With more research on the GPIO pins, there is only one that can do PWM. As i need 4 I am going to abadon the Pi and go to an Arduino which has 6 PWM pins.
mattlewis
Wed Jul 05, 2017 8:56 pm
If you want to Staci with Java you can try use my pigpio wrapper library: https://GitHub.com/mattjlewis/pigpioj.
pigpio supports optimised PWM output on all GPIOs.
For a user friendly interface you could use diozero (http://www.diozero.com/) which supports pigpio as a backend.
Matt
lizardman1499
Thu Jul 06, 2017 2:10 am
mattlewis wrote:If you want to Staci with Java you can try use my pigpio wrapper library: https://GitHub.com/mattjlewis/pigpioj.
Matt
I'm attempting to use your pigpio library and I'm getting this error
Exception in thread "main" java.lang.UnsatisfiedLinkError: PigpioGpio.initialise()I
	at PigpioGpio.initialise(Native Method)
	at PigpioOutputTest.main(PigpioOutputTest.java:9)
mattlewis
Thu Jul 06, 2017 7:25 am
Are you calling
uk.pigpioj.PigpioJ.getImplementation()
? You need to call this method to ensure that the shared library is loaded. I'm just writing up some usage notes on the GitHub project now.
Matt
mattlewis
Thu Jul 06, 2017 7:35 am
I've just noticed my own examples are out of date; updating them too now.
Matt
Return to “Java”
