kaleetre
Probleme by wirringPi
Wed Jun 07, 2017 4:52 pm
i try to lauch a java aplication to my raspberry pi 3 model B+ but i have this error
Exception in thread "main" java.lang.RuntimeException: Unable to open GPIO direction interface for pin [7]: Aucun fichier ou dossier de ce type
at com.pi4j.wiringpi.GpioUtil.export(Native Method)
i have install java jdk and jre, I have install the lastest version of wiring pi and pi4j and i use the snapshoot 1.2 of pi4j so don't understand why it's does'nt work ca, you help mi pls ?
Re: Probleme by wirringPi
Thu Jun 08, 2017 5:43 am
Is your userid connected to the I2C and SPI groups?
What version of WiringPi is installed?
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3B*3, 3B+
Please post ALL technical questions on the forum. Do not send private messages.
megamarky
Mon Jun 12, 2017 11:48 am
Did you get it working? You could try to launch the application with root privileges
sudo java -jar app.jar
Or create a new user and connect it with the groups that Dougie's reply mentioned. Here's a nice reference
https://www.modmypi.com/blog/how-to-add ... -to-groups
GigaBrain.io
Return to “Java”
Who is online
Users browsing this forum: No registered users and 1 guest
