juranga
Cannot execute .jar file [manifest]
Mon May 29, 2017 8:38 am
I am facing some problem compiling a .java file. I just jave a onlySyn.java with two classes (onlySyn and InputStreamRunnable), only onlySyn is a public class, and it has a main function.
This are the steps I have followed:
javac onlySyn.java
This creates two .class files: InputStreamRunnable.class and onlySyn.class
Then, I create a .jar file:
sudo jar cvf Test.jar InputStreamRunnable.class onlySyn.class
added manifest
adding: InputStreamRunnable.class(in = 1076) (out= 612)(deflated 43%)
adding: onlySyn.class(in = 5223) (out= 2734)(deflated 47%)
But when I try to execute a jar file I get the next error:
pi@raspberrypi:~/Documents/CPS $ sudo java -jar ./Test.jar 52.25.25.25 5454 1
no main manifest attribute, in ./Test.jar
What am I missing??
ghans
Re: Cannot execute .jar file [manifest]
Mon May 29, 2017 10:36 am
You are missing a manifest file.
https://en.wikipedia.org/wiki/JAR_%28fi ... 9#Manifest
You can write it by hand , this is a minimal but valid example :
Manifest-Version: 1.0
Main-Class: com.example.MyClassName
https://stackoverflow.com/questions/127 ... le-in-java
Alternatively , specify the main class manually :
https://stackoverflow.com/questions/202 ... at-runtime
ghans
knute
Mon May 29, 2017 4:28 pm
juranga wrote:Hi,
What am I missing??
There needs to be something to tell the java runtime what main class you want to run. There are three ways to make this work.
1) Put your jar file in the class path (this will work with what you have). java -cp YourJar.jar TheClassWithTheMain
2) Jar it with the e option and give it the main class. jar -cvfe YourJar.jar program *.class
3) Create a manifest as ghans suggested and include that in the jar command with the m option. jar -cvfm Your.jar Your.man *.class
clicky
Tue May 30, 2017 7:39 am
If you decided to put some more into coding with Java I wholeheartedly suggest you pick up something like maven and organise project as per it. And adopt IDE of choice to do it in.
I've done something recently and it was similar to:
http://www.mkyong.com/maven/how-to-crea ... ith-maven/
You can, then, build it with:
mvn clean install
To get executable jar just add section as explained here:
https://maven.apache.org/plugins/maven-shade-plugin/examples/executable-jar.html
(don't forget to change <mainClass>org.sonatype.haven.HavenCli</mainClass> to include your class instead of "org.sonatype.haven.HavenCli".
If you are doing it from PC (before transferring it to RPi) you can use Eclipse (or IntelliJ's Idea) and import existing maven project. Speaking of Eclipse (I suspect same goes with Idea) you can even export runnable Jar from 'regular' (non-maven) project, too, but I wouldn't recommend that as you wouldn't like your builds being easily reproduced.
juranga
Tue May 30, 2017 8:41 am
I have finally solved it. I have followed the next commands:
javac OnlySin.java
jar cfe Main.jar OnlySin OnlySin.class InputStreamRunnable.class
Many thanks for all the answers!
Return to “Java”
