ravi0809
Java Web App on raspberry pi
Tue Apr 25, 2017 2:43 am
I want to run a java based web app on my raspberry pi. So please can you guys suggest me a light weight java based application server for raspberry pi?
mattlewis
Re: Java Web App on raspberry pi
Thu Apr 27, 2017 10:09 pm
For web containers try one of Tomcat, Jetty or Undertow. For web frameworks Spark seems quite popular and lightweight.
http://www.diozero.com/
zacburke
Sun Apr 30, 2017 4:34 pm
Just also like to add that there is a framework called Spring Boot.
This is a very popular framework for building java based applications, and if you choose to build a web application with the framework it comes with an embedded version of tomcat,or jetty , or undertow within it.
Its very simple to run, and doesn't need an install, all it needs is a JRE and you just run the jar which gets built from your development environment.
This jar file has all of the dependencies needed.
It really is that simple.
Please have a look here:
https://projects.spring.io/spring-boot/#quick-start
I have used Spring Boot many times, but I havent had the opportunity to use it on the Pi just yet. Maybe you could let us know how you get on.
-Zac
JohnAntonioCollins
Mon May 01, 2017 11:01 pm
I am using Spring Boot on Raspberry Pi. It seems to work very well. Look at my github to see the code: https://github.com/JohnAntonioCollins/MicBotServer .
Does anybody have experience unit testing gpio methods with mock objects instead of integration testing on an actual Raspberry Pi?
Good luck with your server! :)
Return to “Java”
Who is online
Users browsing this forum: No registered users and 2 guests
