Remove openJDK and add Oracle
by mmaceachran » Sun Apr 09, 2017 12:14 am
I have a Linux raspberrypi 4.4.50-v7+ #970 SMP Mon Feb 20 19:18:29 GMT 2017 armv7l GNU/Linux
It aparantly comes with OpenJDK 7 when I run the java -version I get this:
java version "1.7.0_121"
OpenJDK Runtime Environment (IcedTea 2.6.8) (7u121-2.6.8-2~deb8u1+rpi1)
OpenJDK Zero VM (build 24.121-b00, interpreted mode)
I tried running sudo apt-get install oracle-java8-jdk but I get this response:
oracle-java8-jdk is already the newest version.
so it seems that i have that too... ? Can someone explain what is happening here?
Can someone tell me where the Oracle Java is, how do I remove OpenJDK 7, and set my JAVA_HOME to Oracle 8.
by fruitoftheloom » Sun Apr 09, 2017 10:12 am
mmaceachran wrote:I have a Linux raspberrypi 4.4.50-v7+ #970 SMP Mon Feb 20 19:18:29 GMT 2017 armv7l GNU/Linux
Have you fully updated Raspbian Jessie with Pixel, if that is the Operating System installed ?????
sudo apt-get update
sudo apt-get dist-upgrade
I have installed no extra Java related packages and the following:
uname -a
java -version
java version "1.8.0_65"
Java(TM) SE Runtime Environment (build 1.8.0_65-b17)
Java HotSpot(TM) Client VM (build 25.65-b01, mixed mode)
Searching for packages I have "oracle-java8-jdk Java™ Platform, Standard Edition 8 Development Kit " installed
Ex Computer Repair & Service Technician.
RPi 3B, HP Envy 4500 Wireless Printer, Google Chromecast, Android Smart Phone, HD 1080p TV and 3/4G Mobile Internet make ideal companions.
by sm2345110 » Fri May 05, 2017 7:43 am
The syntax is given below for the JAVA:-
for removing the JDK:-
sudo apt-get purge openjdk-\*
and add Oracle:-
Sudo cp -r jdk-8u51-linux-x64.tar.gz /usr/local/java/
All the Best :)
JAVA Training at CETPA..
