Running a terminal command from within Nodejs
Posted: Tue Mar 28, 2017 11:39 am
by CraigDubya
I would like to run the following terminal command from within a javascript file:
echo 0=50% >/dev/servoblaster
I have trawled the internet and must confess that everything I see is confusing me.
I would also like to make the 50% a variable within the javascript that can be passed to the terminal command.
Re: Running a terminal command from within Nodejs
Posted: Tue Mar 28, 2017 6:59 pm
by CraigDubya
After finding the answer I thought I would share here for anyone interested.
#!/bin/bash
var exec = require('child_process').exec;
var Blynk = require('/usr/lib/node_modules/blynk-library');
var AUTH = 'YOUR AUTH TOKEN GOES HERE';
var blynk = new Blynk.Blynk(AUTH);
var v2 = new blynk.VirtualPin(2);
v2.on('write', function(param) {
exec('echo 0='+param[0]+'% >/dev/servoblaster', function (err,stdout,stderr) {})
As you can see I am using blynk to control a servo (which is attached to a webcam)
The code line I was looking for was:
I also needed to import the child_process exec command using:
