WalkingThrough
Java, Eclipse, SWT on Jessie?
Wed Nov 16, 2016 2:18 am
Hello -
Installing Jessie went smoothly, no glitches. Following instructions, an external USB-connected hard drive was partitioned, rsync used to copy everything to the HD, /boot/config.txt fixed to point to /dev/sda2 as the root partition, and it all just works.
Java 7 is supplied... but Java 8 from Oracle is available. After some reading, managed to install Eclipse 8 and now things are a bit zippier.
Now I'm trying to write code that uses SWT. The system comes with /usr/share/java/swt.jar; it's a soft link to /lib/java/swt-gtk-3.8.2.jar .
Launch Eclipse, create a new Java project, type in a 'Hello world' (yes, it worked) then went to the top bar.
Project --> Properties --> Java Build Path --> Add External Jars. Navigate to /usr/share/java, select swt.jar, and left-click "Ok".
Eclipse shows swt-gtk-3.8.2 - /usr/lib/java and I think, "That seemed straightforward." The first hint of problems was left-clicking to expand the jar file and not finding anything in it.
In the class containing main(), I create a class variable:
DISPLAY display = null;
There's a red blit at the left. "DISPLAY cannot be resolved to a type".
CTRL-SHIFT O to Organize Imports. If this were done under Slackware Linux or Windows, Eclipse would happily populate the source window with import statements. Like: import org.eclipse.swt.widgets.Display;
What step(s) am I missing? It would be nice to have the same functionality under Jessie that is available under other platforms... but those platforms (both x86-based) offer a complete importable project.
Is that available under Jessie for the Raspberry Pi ?
Your time is appreciated.
WalkingThrough
Re: Java, Eclipse, SWT on Jessie?
Sun Dec 11, 2016 5:45 am
I stared for a few weeks at this problem before it finally sank in that I was doing it all wrong.
Have finally gotten the online SWT documentation to pop up under a hovering cursor and everything works. Well mostly.. but for what I use, it works.
Now I'm trying to get WindowBuilder working. Oh, it installs fine. But invoking it causes a complaint about the wrong operating environment. Now I'm looking around for Mars or Neon Eclipse for the Pi.
Ya3ny
Thu Jan 04, 2018 9:00 pm
Did you get WindowBuilder to work on the Pi using any OS?
Return to “Java”
Who is online
Users browsing this forum: No registered users and 4 guests
