eHat
Java ME FileConnection problem
Wed Apr 20, 2016 1:05 am
I am trying to read a file on my Raspberry Pi using the following code without success.
FileConnection fconn = (FileConnection) Connector.open("file:///" + path, Connector.READ);
After printing out the roots using this code
Enumeration em = FileSystemRegistry.listRoots();
            while(em.hasMoreElements()){
                System.out.println(em.nextElement());
I get the following roots:
_dev_root/
devtmpfs/
sysfs/
proc/
tmpfs/
devpts/
tmpfs/
tmpfs/
tmpfs/
cgroup/
cgroup/
cgroup/
cgroup/
cgroup/
cgroup/
cgroup/
systemd-1/
mqueue/
debugfs/
configfs/
fusectl/
_dev_mmcblk0p1/
tmpfs/
gvfsd-fuse/
_dev_sda/
And my real root is not among them.
Is there a solution to this problem, adding a root maybe?[/url]
MarkHaysHarris777
Re: Java ME FileConnection problem
Wed Apr 20, 2016 2:37 am
eHat wrote: I get the following roots:
_dev_root/
Your real root is hiding right there in front of you.
Use the df command from a terminal... your real root / will show as:
/dev/root /
marcus
marcus
:ugeek:
eHat
Wed Apr 20, 2016 11:15 am
So simple, it works like a charm.
Tank you :)
Br, Edvin
Return to “Java”
