levo
Java GUI Problem
Thu Feb 25, 2016 1:59 pm
I have a Java application without any GUI on NetBeans(on my windows 7 computer) and I can run and debug it on Raspberry Pi 2 using remote java run time property.
However, when I try to run and debug another Java application with Swing GUI on Raspberry Pi 2 using the same remote java run time approach, I get the exception: "No X11 DISPLAY variable was set, but this program performed an operation which requires it." My Raspberry Pi 2 has a monitor connected via HDMI.
I do not want and need to see the application's GUI on my windows 7 computer but I must see and interact the GUI on Raspberry Pi 2's monitor. How can I do that?
ghans
Re: Java GUI Problem
Thu Feb 25, 2016 2:46 pm
thioaana
Sun Dec 17, 2017 6:37 pm
i also have the problem described above.
Can anybody help me ?
thioaana
Mon Dec 25, 2017 7:28 am
Hi again.
I found it.
In case someone else will have the same problem, the solution is the next two lines
export DISPLAY=IpWindowsUser:0.0
sudo /usr/lib/jvm/jdk-8-oracle-arm32-vfp-hflt/jre/bin/java -Dfile.encoding=UTF-8 -jar CarController_1.jar (for my project).
Return to “Java”
