I am trying to enable a 2-way Audio communication using Java Servlets between RPi and a windows machine. The same java program works fine between two windows 8 machines but not between a RPi and a window machine.It simply threw the following exception when invoked using a browser. How to deal with awt error? Also, he RPi does not have a mic
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error that prevented it from fulfilling this request.
exception
java.awt.HeadlessException:
No X11 DISPLAY variable was set, but this program performed an operation which requires it.
java.awt.GraphicsEnvironment.checkHeadless(GraphicsEnvironment.java:207)
java.awt.Window.<init>(Window.java:536)
java.awt.Frame.<init>(Frame.java:420)
javax.swing.JFrame.<init>(JFrame.java:225)
com.teqnihome.tech.Client1.starter(Client1.java:55)
com.teqnihome.tech.Clientservlet.doGet(Clientservlet.java:21)
javax.servlet.http.HttpServlet.service(HttpServlet.java:622)
javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
note The full stack trace of the root cause is available in the Apache Tomcat/8.0.24 logs.
