zhoozhoo
Which JDK 8 binary should I install on Raspbian?
Thu Feb 11, 2016 6:45 pm
I'm trying to upgrade JDK 8 that came with Raspbian Jessie to the latest version, but there are multiple binaries avaiable on Oracle web site:
1. Java SE Development Kit Linux ARM v6/v7 Hard Float ABI (jdk-8u73-linux-arm32-vfp-hflt.tar.gz)
2. Java SE Development Kit Linux ARM v6/v7 Hard Float ABI (jdk-8u73-linux-arm64-vfp-hflt.tar.gz)
3. Java SE Embedded Version 8 Update 73 - ARMv5/ARMv6/ARMv7 Linux - SoftFP ABI, Little Endian 2 (ejdk-8u73-linux-arm-sflt.tar.gz)
4. Java SE Embedded Version 8 Update 73 - ARM v6/v7 Linux - VFP, HardFP ABI, Little Endian 1 (ejdk-8u73-linux-armv6-vfp-hflt.tar.gz)
Which one is the right one?
mattlewis
Re: Which JDK 8 binary should I install on Raspbian?
Fri Feb 12, 2016 12:22 pm
Personally I just use the Oracle JDK provided by raspbian (currently JDK 8u65):
sudo apt-get update && sudo apt-get install oracle-java8-jdk
java -version
java version "1.8.0_65"
Java(TM) SE Runtime Environment (build 1.8.0_65-b17)
Java HotSpot(TM) Client VM (build 25.65-b01, mixed mode)
Matt
http://www.diozero.com/
xranby
Fri Feb 12, 2016 12:30 pm
Option 1 or 4 is correct for use on a Rasbian system
Option 2 requires a 64 bit CPU
Option 3 requires a "soft-float" linux system where all applications are compiled *not* to use a floating point VFP unit., it uses a different ABI compared to Raspbian.
Xerxes Rånby @xranby I once had two, then I gave one away. Now both are in use every day!
twitter.com/xranby
zhoozhoo
Fri Feb 12, 2016 3:44 pm
Thanks for the answers!
Return to “Java”
