bent55
How can I transfer any image file with bluetooth using JAVA?
Thu Feb 11, 2016 2:53 pm
I want to image transfer from Android phone to JAVA program. I use raspberry pi 2 and I have HC-05 bluetooth module. Specifically, I want to transfer image file in any raspberry directory such as /home/pi/images folder. How can I transfer any image file with bluetooth on raspberry pi 2 using JAVA program?
Thank you.
Douglas6
Re: How can I transfer any image file with bluetooth using J
Thu Feb 11, 2016 3:02 pm
Using an HC-05, you are limited to serial communications. You could try installing PPP, you could use ancient serial protocols like xmodem, or you could simply read and write the file a few bytes at a time. Transfer speeds will vary from slow to really slow.
bent55
Thu Feb 11, 2016 3:31 pm
Thank you for your reply.
Actually, I was wrong. I use HC-06. Is it different? If it is very slow, how can I transfer image with WiFi direct?
scotty101
Thu Feb 11, 2016 3:43 pm
Have you seen this?
http://www.instructables.com/id/Make-Ra ... th-Object/
You probably need a USB Bluetooth adapter rather than the one you have since it is limited to a serial protocol.
P.S. WiFi direct and Bluetooth are totally different things.....
Douglas6
Thu Feb 11, 2016 3:52 pm
Yes, the HC-05 and HC-06 are essentially the same. With a USB Bluetooth dongle, you can use OBEX file exchange, but if WiFi is an option, that's the way to go.
Return to “Java”
