sudo ./usertest.sh Code: Select all
Java is starting. Press Ctrl-C to exit
Frame buffer device detected: BCM2708
Frame buffer '/dev/fb0' detected: 656x416, depth=16
Failed to open /dev/input/by-id
[ERROR] [LCD] iso=-1:javacall_init_frame_buffer: failed to init keyboards
[CRITICAL] [PROXY] iso=-1:Can't create server
can not connect to device manager
[ERROR] [AMS] iso=0:The MIDlet suite could not be run.
