tonyfaros
Interchange data between arduino and raspberry
Wed Dec 09, 2015 9:43 pm
Hi guys. How or is it even possible to get data from the arduino to a java program (running on the raspberry). The arduino is also connected to the raspberry by the idle on raspbian.
torntrousers
Re: Interchange data between arduino and raspberry
Thu Dec 10, 2015 8:41 am
If the Arduino is connected to the Pi with USB then this enables communicating with the Arduino from a Java app - https://developer.ibm.com/wasdev/docs/g ... ng-arduino
savageautomate
Fri Dec 11, 2015 5:52 pm
You could also build your own communication interface/bridge using serial (UART) communications if you don't want to go the USB route.
-Robert
Robert Savage | Follow me @savageautomate
http://www.pi4j.com | http://www.pislices.com
http://www.savagehomeautomation.com
Return to “Java”
