Why didnt you try PI4J ? A very userfriendly Java Library for RaspberryPI.
www.pi4j.com
You should try out CodeRASPIDe. This is an IDE under Development for RaspberryPI.
CodeRASPIde is our small contribution to the IoT and Java Eclipse Community.
This IDE is ment for Beginners and is based on PI4J libraries. You design and it generates the required code.
Visit :
http://www.ancitconsulting.com/coderaspide/index.html
Features Included
Project Wizard for Creating a new PI4J Project
Java Project with PI4J Library added to ClassPath
Configuration File for RasberryPI Programming with extn .picfg
Modeling Editor for Editing the RasberryPI Model
PIN Status Diagram indicating the USE of the PINs
Zest based Code Visualizer to represent the current Flow Diagram
Remote Execution and Debug from Eclipse on RasberryPI using LaunchPI Plugins
Currently Supports 40PIN based RaspberryPI Boards
RaspberryPI A+
RaspberryPI B+
RaspberryPI 2
- See more at:
https://marketplace.eclipse.org/content ... spberry-pi
