kv1402
Application for getting status
Sun Oct 04, 2015 8:34 am
Hi, I was how to make a java program that can get status information about the temperature, CPU info etc. from raspberry pi?
I dont know where to start. :?
savageautomate
Re: Application for getting status
Mon Oct 05, 2015 11:00 am
If you want to use a library, then a lot of system information is already aggregated for you and accessible via simple Java interfaces using the Pi4J library. Here is the system information example:
http://pi4j.com/example/system-info.html
This example is included in Pi4J if you install it on your Raspberry Pi. It will be in the directory:
cd /opt/pi4j/examples
You can use the Pi4J shell script to compile it and run it.
Compile:
pi4j --compile SystemInfoExample.java
Run:
pi4j SystemInfoExample
If you want the code or to know where Pi4J sources this information you can review the classes listed here:
https://github.com/Pi4J/pi4j/tree/devel ... i4j/system
Good Luck!
Robert
Robert Savage | Follow me @savageautomate
http://www.pi4j.com | http://www.pislices.com
http://www.savagehomeautomation.com
kv1402
Tue Oct 06, 2015 10:22 pm
savageautomate wrote:If you want to use a library, then a lot of system information is already aggregated for you and accessible via simple Java interfaces using the Pi4J library. Here is the system information example:
Compile:
Run:
Good Luck!
Robert
Thank you Robert, I will try this. :D
Return to “Java”
