sabatiello
Problem Jquery
Tue Sep 08, 2015 11:26 am
I created a index.html as this http://jsfiddle.net/romimmo/wmroLbwe/ with 2 swich on/off. On http://jsfiddle.net/ the switches works well but on my server i can't view a pop up "checked or unchecked" Can you help me??
On my server I have:
index.html
<html>
	<head>
		<title>MImmo Prova</title>
		<link rel="stylesheet" href="/style.css" type="text/css">
		<script src='http://code.jquery.com/jquery-1.10.2.js'></script>
		<script type="text/javascript" src="/jquery-1.10.2.min.js"></script>
		<script type="text/javascript" src="/script.js"></script>
	</head>
	<body>
		<div class="onoffswitch">
<input id="myonoffswitch" type="checkbox" name="onoffswitch" class="onoffswitch-checkbox"/>
<label class="onoffswitch-label" for="myonoffswitch">
<div class="onoffswitch-inner"></div>
<div class="onoffswitch-switch"></div>
</label>
</div>
<br></br>
<div class="onoffswitch1">
<input id="myonoffswitch1" type="checkbox" name="onoffswitch1" class="onoffswitch-checkbox"/>
<label class="onoffswitch-label" for="myonoffswitch1">
</label>
	</body>
</html>
style.css
body
    background-color: #666;
.onoffswitch {
      position: relative;
      width: 82px;
      -webkit-user-select:none;
      -moz-user-select:none;
      -ms-user-select: none;
    .onoffswitch-checkbox {
      display: none;
    .onoffswitch-label {
      display: block; overflow: hidden; cursor: pointer;
      border: 2px solid #FFFFFF; border-radius: 5px;
    .onoffswitch-inner {
      width: 200%;
      margin-left: -100%;
      -moz-transition: margin 0.3s ease-in 0s;
      -webkit-transition: margin 0.3s ease-in 0s;
      -o-transition: margin 0.3s ease-in 0s;
    .onoffswitch-inner:before, .onoffswitch-inner:after {
    float: left; width: 50%; height: 24px; padding: 0; line-height: 24px;
    font-size: 18px; color: white; font-family: Trebuchet, Arial, sans-serif; font-weight: bold;
    -moz-box-sizing: border-box; -webkit-box-sizing: border-box; box-sizing: border-box;
    .onoffswitch-inner:before {
      content: "on";
      padding-left: 14px;
      background-color: #2FFF3D;
      color: #FFFFFF;
      content: "off";
      padding-right: 14px;
      background-color: #ADADAD;
      color: #FFFFFF;
      text-align: right;
    .onoffswitch-switch {
      width: 28px; margin: 0px;
      background: #FFFFFF;
      position: absolute; top: 0; bottom: 0; right: 50px;
      -moz-transition: all 0.3s ease-in 0s; -webkit-transition: all 0.3s ease-in 0s;
      -o-transition: all 0.3s ease-in 0s; transition: all 0.3s ease-in 0s;
      background-image: -moz-linear-gradient(center top, rgba(0,0,0,0.1) 0%, rgba(0,0,0,0) 100%);
      background-image: -webkit-linear-gradient(center top, rgba(0,0,0,0.1) 0%, rgba(0,0,0,0) 100%);
      background-image: -o-linear-gradient(center top, rgba(0,0,0,0.1) 0%, rgba(0,0,0,0) 100%);
      background-image: linear-gradient(center top, rgba(0,0,0,0.1) 0%, rgba(0,0,0,0) 100%);
    .onoffswitch-checkbox:checked + .onoffswitch-label .onoffswitch-inner {
      margin-left: 0;
    .onoffswitch-checkbox:checked + .onoffswitch-label .onoffswitch-switch {
      right: 0px;
body
.onoffswitch1 {
      position: relative;
      width: 82px;
      display: none;
      width: 200%;
      margin-left: -100%;
      content: "on";
      padding-left: 14px;
      color: #FFFFFF;
      content: "off";
      color: #FFFFFF;
      text-align: right;
      margin-left: 0;
      right: 0px;
script.js
$("#myonoffswitch").click(function(){
            if($("#myonoffswitch").is(":checked"))
                alert('checked');
            else
                 alert('unchecked');
 $("#myonoffswitch1").click(function(){
            if($("#myonoffswitch1").is(":checked"))
                alert('checked 1');
            else
                 alert('unchecked 1');
xranby
Re: Problem Jquery
Tue Sep 08, 2015 12:13 pm
Try change the href to the style.css and src to the js files and remove the initial /
that would make the URL's relative and the browser will look for the files next to the index.html file.
like this:
      <link rel="stylesheet" href="style.css" type="text/css">
      <script type="text/javascript" src="jquery-1.10.2.min.js"></script>
      <script type="text/javascript" src="script.js"></script>
You need to show use the URL to your server if you want help debug this further.
Xerxes Rånby @xranby I once had two, then I gave one away. Now both are in use every day!
twitter.com/xranby
sabatiello
Re: Problem Jquery
Tue Sep 08, 2015 1:10 pm
I removed the initial / ma it does't work well. This is my server test url http://test1979.no-ip.info:8000/
Massi
Re: Problem Jquery
Tue Sep 08, 2015 1:22 pm
shouldn't it be like this?
$(document).ready(function(){
                alert('checked');
            else
                 alert('unchecked');
                alert('checked 1');
            else
sabatiello
Re: Problem Jquery
Tue Sep 08, 2015 1:34 pm
Thank you guys, it works well now ;)
Massi
Re: Problem Jquery
Tue Sep 08, 2015 1:35 pm
grande Mimmo :)
Return to “Java”
