gmseed
BlueJ Installation
Sat Aug 29, 2015 7:21 pm
Hi
I'm new to Raspberry PI and trying to install BlueJ according to the instructions at:
http://www.bluej.org/raspberrypi/
which states type:
sudo dpkg -i bluej-315.deb
upon which I get the error:
pi@raspberrypi ~ $ sudo dpkg -i bluej-315.deb
dpkg: error processing bluej-315.deb (--install):
cannot access archive: No such file or directory
bluej-315.deb
pi@raspberrypi ~ $
Anyone else seen this issue?
Graham
xranby
Re: BlueJ Installation
Sun Aug 30, 2015 8:25 am
The official BlueJ guide is too vauge how to do the "Just download the Raspbian installer" step.
Try the following two commands; combined they will first download the bluej "deb" installer file using the wget tool and then install it using the dpkg tool.
wget http://bluej.org/download/files/bluej-315.deb
Xerxes Rånby @xranby I once had two, then I gave one away. Now both are in use every day!
twitter.com/xranby
Return to “Java”
