zugdu39z
[SOLVED]A fatal error Java Runtime Environment .v 6.0_35-b35
Wed Aug 12, 2015 1:17 pm
Hi!
Till two days I will get the failure into my console.
# A fatal error has been detected by the Java Runtime Environment:
# Internal Error (os_linux_zero.cpp:285), pid=13567, tid=1374155888
# fatal error: caught unhandled signal 11
# JRE version: 6.0_35-b35
# Java VM: OpenJDK Zero VM (23.25-b01 mixed mode linux-arm )
# Derivative: IcedTea6 1.13.7
# Distribution: Debian GNU/Linux 7.8 (wheezy), package 6b35-1.13.7-1~deb7u1+rpi1
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /home/pi/hs_err_pid13567.log
# If you would like to submit a bug report, please include
# instructions how to reproduce the bug and visit:
# http://icedtea.classpath.org/bugzilla
Here are the contend inside from /ome/pi/hs_err_pid13567.log http://up.picr.de/22800879qg.jpg
Please help me!
xranby
Re: A fatal error Java Runtime Environment .v 6.0_35-b35
Wed Aug 12, 2015 4:24 pm
If there is a reliable way to reproduce the bug then it can get studied. By reading your log-file all I can see is that you have been running jdownloader for 2 days. Unfortunally there is no "core" file generated, that can be used to attach a debugger in order to find out why the program crashed.
You can try using a different JVM, right now you use openjdk-6
if you update to openjdk-7-jre then you will use a more up to date java virtual machine
if you have installed many java versions on one pi then you can use the
update-java-alternatives -l
tool to list all installed variants
and use
sudo update-java-alternatives -s java-1.7.0-openjdk-armhf
to switch the default java on your Raspbian system.
Xerxes Rånby @xranby I once had two, then I gave one away. Now both are in use every day!
twitter.com/xranby
zugdu39z
Wed Aug 12, 2015 6:10 pm
Hi thanks for reply!!
I have with the order
now 4 versions installed.
java-1.6.0-openjdk-armhf 1057 /usr/lib/jvm/java-1.6.0-openjdk-armhf
java-1.7.0-openjdk-armhf 1043 /usr/lib/jvm/java-1.7.0-openjdk-armhf
jdk-7-oracle-armhf 317 /usr/lib/jvm/jdk-7-oracle-armhf
jdk-8-oracle-arm-vfp-hflt 318 /usr/lib/jvm/jdk-8-oracle-arm-vfp-hflt
I don't know how!
the order
gives me that as answer:
pi@WoW ~ $
update-alternatives: error: no alternatives for jcmd
update-alternatives: error: no alternatives for jhat
update-alternatives: error: no alternatives for jrunscript
update-alternatives: error: no alternatives for mozilla-javaplugin.so
update-alternatives: error: no alternatives for schemagen
update-alternatives: error: no alternatives for wsgen
update-alternatives: error: no alternatives for wsimport
update-alternatives: error: no alternatives for xjc
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/appletviewer
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/extcheck
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/idlj
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/jarsigner
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/javac
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/javadoc
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/javah
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/javap
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/jcmd
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/jconsole
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/jdb
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/jhat
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/jinfo
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/jmap
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/jps
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/jrunscript
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/jsadebugd
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/jstack
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/jstatd
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/native2ascii
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/rmic
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/schemagen
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/serialver
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/wsgen
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/wsimport
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/bin/xjc
update-java-alternatives: plugin alternative does not exist: /usr/lib/jvm/java-7-openjdk-armhf/jre/lib/arm/IcedTeaPlugin.so
should I deinstall the other version and should I have only the version
installed?
xranby
Wed Aug 12, 2015 11:06 pm
the errors seen above is "ok"
the reason is that you have the openjdk-7 runtime JRE and the JRE do not contain the many java developer tools such as the appletviewer and javac .
the missing webbrowser java plugins can be obtained if you install the icedtea-7-plugin
you can get all the tools and plugins in the list if you install openjdk-7-jdk and icedtea-7-plugin.
The JRE that you have installed is enough if you simply want to run applications such as jdownloader.
zugdu39z wrote: should I deinstall the other version and should I have only the version
installed?
No, you do not need to uninstall the other versions.
Try switch version if you run into issues with jdownloader.
twitter.com/xranby
zugdu39z
Thu Aug 13, 2015 5:53 am
Hi there!
Now I have installed the two things here:
apt-get install openjdk-7-jdk
and
apt-get install icedtea-7-plugin
and made a fresh restart.
Now it will work to extract the downloads in my Jdownloader after I push the button under downloads -> package -> actions -> extract now.
But automatic it dosn't work.
I will have a look at the message of my java in the console and if the Jdownloader will work 24 h in a day without a failure.
Here are my comments in the console:
http://up.picr.de/22806522ai.png
xranby
Thu Aug 13, 2015 1:52 pm
zugdu39z wrote:Now it will work to extract the downloads in my Jdownloader after I push the button under downloads -> package -> actions -> extract now.
No idea, you have to talk to the jdownload developers
you should provide a step by step instruction how to reproduce the "bug" that "automatic unpacking do not work"
so that the developers can reproduce and observe the same issue.
http://jdownloader.org/knowledge/wiki/support/bugreport
zugdu39z wrote: I will have a look at the message of my java in the console and if the Jdownloader will work 24 h in a day without a failure.
it will most likely working work fine now.
zugdu39z wrote: Here are my comments in the console:
All ok! normal output seen when you install new packages.
twitter.com/xranby
zugdu39z
Thu Aug 13, 2015 4:47 pm
Hi!
It seems that in the moment all is okay with jdownloader and the extract prozess works by now automatic.
Thank you for your help!
Kind regards!
Return to “Java”
