RFID reader RC522 SPI usage
Posted: Mon Jul 06, 2015 11:37 am
by p4ppo
I'm trying to use my RFID reader with pi4j libraries, but with no success.
It is connected through SPI interface (MISO-MOSI, SCK and SDA). I have the SPI ports correctly opened on my raspberry.
I cannot even start to think how to manage it, no way to know how to read from the reader.
Anyone has already solved this problem or simply address me to the right road?
Re: RFID reader RC522 SPI usage
Posted: Mon Jul 06, 2015 12:39 pm
by mikronauts
Why SDA?
It should be /CE0 or /CE1, and you also need to connect GND
Also, if your RFID reader has 5V outputs, you need to divide MISO down to 3v3
p4ppo wrote:Hello,
Posted: Mon Jul 06, 2015 1:16 pm
by p4ppo
mikronauts wrote:Why SDA?
p4ppo wrote:Hello,
Obviously it's connected to the ground and the 3.3V pin.
I've connected it like this picture, as I've seen in a lot of tutorials around the web...
http://bsd.ee/~hadara/blog/wp-content/u ... id_rPi.jpg
Is this wrong?
It works with python, i just need to make it work with pi4j
Posted: Mon Jul 06, 2015 1:28 pm
by mikronauts
If it works with Python, then it is wired correctly, and your issue is a pi4j software.
p4ppo wrote: Obviously it's connected to the ground and the 3.3V pin.
Is this wrong?
Posted: Mon Jul 06, 2015 1:33 pm
by p4ppo
mikronauts wrote:If it works with Python, then it is wired correctly, and your issue is a pi4j software.
Is this wrong?
Yes I know, but my problem is that i really don't know how to set up it with pi4j, si i was asking if anyone has already made it, so to give me some advice.
Posted: Mon Jul 06, 2015 1:48 pm
by mikronauts
Sorry, I have never used pi4j otherwise I'd help.
Best guess: google for pi4j spi problem and see if you see anything that might help.
p4ppo wrote:
mikronauts wrote: Yes I know, but my problem is that i really don't know how to set up it with pi4j, si i was asking if anyone has already made it, so to give me some advice.
Posted: Wed Jul 22, 2015 2:55 am
by ahlie
I also make it work with Python and wish to migrate it to Java. Due to the time limitation, I use Java to call the Python scripts as a compromise.
Posted: Fri Feb 17, 2017 3:25 pm
by freemo716
@p4ppo
do you have any solution o pi4j ?
i stuck in same problem too , working with python but not 9i4j :(
Posted: Fri Feb 17, 2017 8:52 pm
by mattlewis
I've almost got this wokring in Java in my diozero library. See https://github.com/mattjlewis/diozero/b ... RC522.java.
Just ironing out some authentication issues. The MFRC522 Python code this is based on has some very strange logic in places.
Matt
Posted: Fri Feb 17, 2017 9:09 pm
by joan
mattlewis wrote:I've almost got this wokring in Java in my diozero library. See https://github.com/mattjlewis/diozero/b ... RC522.java.
Matt
The Python versions I have seen are just a port of an Arduino library and seem to have copied all the Arduino quirks verbatim.
I have a Python version which is more based on the datasheets if you want to look at an alternative implementation.
Posted: Fri Feb 17, 2017 9:20 pm
by mattlewis
That would be great - I've yet to find a decent RC522 implementation. I normally try to develop from datasheets plus use a Python implementation for reference, but am really struggling with this one.
I believe authenticate is working now (a port of the Read.py from this implementation https://github.com/mxgxw/MFRC522-python), I can get the card uid and read sectors; I've not looked at write functionality yet (tbh I'm not fully up to speed on the capabilities of these devices). I've got a lot of debug code to remove!
FYI the code in this library should be fully portable to any SBC that runs Linux and Java.
Matt
Posted: Fri Feb 17, 2017 9:34 pm
by joan
This is the class (RC522.py)
#!/usr/bin/env python
import time
OK                  = 0
ERR_NO_TAG          = 1
ERR_UNKNOWN         = 2
ERR_BAD_CRC         = 3
ERR_BAD_LEN         = 4
ERR_TIMEOUT_1       = 5
ERR_TIMEOUT_2       = 6
ERR_BAD_ACCESS_BITS = 7
SPI_CE0      = 0
SPI_CE1      = 1
AUX_SPI_CE0  = 2
AUX_SPI_CE1  = 3
AUX_SPI_CE2  = 4
KEY_A = 0
KEY_B = 1
DBG_OFF=0
DBG_MIN=1
DBG_MAX=2
You need three hardware components
1) a Raspberry Pi
2) a PCD (Proximity Coupling Device), e.g. NXP MFRC522 card reader
3) a PICC (Proximity Integrated Circuit Card), e.g. a Mifare tag
The Pi and the PCD may communicate via SPI, I2C, or a serial link.
This impememtation uses SPI.
The card reader (PCD) and the tags (PICC) communicate using a 13.56MHz radio
link.
The protocol is defined in
ISO/IEC 14443-3 Identification cards
Contactless integrated circuit cards
Proximity cards
Part 3: Initialization and anticollision
See http://wg8.de/wg8n1496_17n3613_Ballot_FCD14443-3.pdf
If only the PICC UID is wanted, the above document has all the needed
information.
To read and write from MIFARE PICCs, the MIFARE protocol is used after
the PICC has been selected.
The MIFARE chips and protocol are described in the following datasheets
1K: http://www.mouser.com/ds/2/302/MF1S503x-89574.pdf
4K: http://datasheet.octopart.com/MF1S7035DA4,118-NXP-Semiconductors-datasheet-11046188.pdf
Mini: http://www.idcardmarket.com/download/mifare_S20_datasheet.pdf
Ultralight:   http://www.nxp.com/documents/data_sheet/MF0ICU1.pdf
Ultralight C: http://www.nxp.com/documents/short_data_sheet/MF0ICU2_SDS.pdf
1K
16 sectors * 4 blocks/sector * 16 bytes/block = 1024 bytes.
The blocks are numbered 0-63.
Block 3 in each sector is the Sector Trailer
   Bytes 0-5:   Key A
   Bytes 6-8:   Access Bits
   Bytes 9:     User data
   Bytes 10-15: Key B (or user data)
Block 0 is read-only manufacturer data, sometimes as follows,
 0 1 2 3 |4  | 5 |6   |7 8 9 A B C D E F
 UID     |BCC|SAK|ATAQ|Manufacturer data
To access a block, an authentication using a key from the block's sector must be performed first.
Example: To read from block 10, first authenticate using a key from sector 3 (blocks 8-11).
All keys are set to FFFFFFFFFFFFh at chip delivery.
WARNING: Please read section 8.7 "Memory Access".
"if the PICC detects a format violation the whole sector
is irreversibly blocked."
To use a block in "value block" mode (for Increment/Decrement operations)
you need to change the sector trailer. Use MIFARE_SetAccessBits()
to calculate the bit patterns.
4K
32 sectors * 4 blocks/sector * 16 bytes/block = 2048 bytes +
8 sectors * 16 blocks/sector * 16 bytes/block = 2048 bytes.
The blocks are numbered 0-255.
The last block in each sector is the Sector Trailer as for the 1K.
Mini
5 sectors * 4 blocks/sector * 16 bytes/block = 320 bytes.
The blocks are numbered 0-19.
Ultralight
16 pages of 4 bytes = 64 bytes.
Pages 0-1 are used for the 7-byte UID.
Page 2 contains the last check digit for the UID, one byte manufacturer internal data, and the lock bytes
Page 3 is OTP, One Time Programmable bits. Once set to 1 they cannot revert to 0.
Pages 4-15 are read/write unless blocked by the lock bytes in page 2.
Ultralight
48 pages of 4 bytes = 192 bytes.
Pages 4-39 are read/write unless blocked by the lock bytes in page 2.
Page 40 Lock bytes
Page 41 16 bit one way counter
Pages 42-43 Authentication configuration
Pages 44-47 Authentication key
Access conditions for sector trailer
  KeyA  Bits  KeyB
  R  W  R  W  R  W
0 -  A  A  -  A  A
1 -  A  A  A  A  A Default
2 -  -  A  -  A  -
3 -  B  AB B  -  B
4 -  B  AB -  -  B
5 -  -  AB B  -  -
6 -  -  AB -  -  -
7 -  -  AB -  -  -
Access conditions for data blocks
    R   W   +  -X
0  AB  AB  AB  AB Data  Default
1  AB  --  --  AB Value
2  AB  --  --  -- Data
3   B   B  --  -- Data
4  AB   B  --  -- Data
5   B  --  --  -- Data
6  AB   B   B  AB Value
7  --  --  --  -- Data
class PCD:
   Workflow
   Call ISO_Request() to check to see if a tag is in range and if so
   get its ATQA.
   Upon success call ISO_Anticollision() which returns the UID of the
   active tag in range.
   Upon success call ISO_Select(UID) which selects the active tag in
   range by its UID and returns its SAK.
   If the card needs authentication call ISO_Authenticate(blockAddr,
   keyId, key, UID) to authenticate access to a block.
   Call ISO_StopCrypto() when you have finished talking to a card
   which requires authentication.
   #_Reserved       = 0x00<<1
   _CommandReg      = 0x01<<1
   _ComlEnReg       = 0x02<<1
   _DivlEnReg       = 0x03<<1
   _CommIrqReg      = 0x04<<1
   _DivIrqReg       = 0x05<<1
   _ErrorReg        = 0x06<<1
   _Status1Reg      = 0x07<<1
   _Status2Reg      = 0x08<<1
   _FIFODataReg     = 0x09<<1
   _FIFOLevelReg    = 0x0A<<1
   _WaterLevelReg   = 0x0B<<1
   _ControlReg      = 0x0C<<1
   _BitFramingReg   = 0x0D<<1
   _CollReg         = 0x0E<<1
   #_Reserved       = 0x0F<<1
   #_Reserved       = 0x10<<1
   _ModeReg         = 0x11<<1
   _TxModeReg       = 0x12<<1
   _RxModeReg       = 0x13<<1
   _TxControlReg    = 0x14<<1
   _TxASKReg        = 0x15<<1
   _TxSelReg        = 0x16<<1
   _RxSelReg        = 0x17<<1
   _RxThresholdReg  = 0x18<<1
   _DemodReg        = 0x19<<1
   #_Reserved       = 0x1A<<1
   #_Reserved       = 0x1B<<1
   _MfTxReg         = 0x1C<<1
   _MfRxReg         = 0x1D<<1
   #Reserved       = 0x1E<<1
   _SerialSpeedReg  = 0x1F<<1
   #_Reserved       = 0x20<<1
   _CRCResultRegM   = 0x21<<1
   _CRCResultRegL   = 0x22<<1
   _Reserved21      = 0x23<<1
   _ModWidthReg     = 0x24<<1
   #_Reserved       = 0x25<<1
   _RFCfgReg        = 0x26<<1
   _GsNReg          = 0x27<<1
   _CWGsPReg        = 0x28<<1
   _ModGsPReg       = 0x29<<1
   _TModeReg        = 0x2A<<1
   _TPrescalerReg   = 0x2B<<1
   _TReloadRegH     = 0x2C<<1
   _TReloadRegL     = 0x2D<<1
   _TCounterValRegH = 0x2E<<1
   _TCounterValRegL = 0x2F<<1
   #_Reserved       = 0x30<<1
   _TestSel1Reg     = 0x31<<1
   _TestSel2Reg     = 0x32<<1
   _TestPinEnReg    = 0x33<<1
   _TestPinValueReg = 0x34<<1
   _TestBusReg      = 0x35<<1
   _AutoTestReg     = 0x36<<1
   _VersionReg      = 0x37<<1
   _AnalogTestReg   = 0x38<<1
   _TestDAC1Reg     = 0x39<<1
   _TestDAC2Reg     = 0x3A<<1
   _TestADCReg      = 0x3B<<1
   #_Reserved       = 0x3C<<1
   #_Reserved       = 0x3D<<1
   #_Reserved       = 0x3E<<1
   #_Reserved       = 0x3F<<1
   # MFRC522 commands
   _PCD_Idle             = 0x00
   _PCD_Mem              = 0x01
   _PCD_GenerateRandomID = 0x02
   _PCD_CalcCRC          = 0x03
   _PCD_Transmit         = 0x04
   _PCD_NoCmdChange      = 0x07
   _PCD_Receive          = 0x08
   _PCD_Transceive       = 0x0C
   _PCD_Authent          = 0x0E
   _PCD_SoftReset        = 0x0F
   # PICC commands
   _PICC_REQA          = 0x26
   _PICC_MF_READ       = 0x30
   _PICC_HLTA          = 0x50
   _PICC_WUPA          = 0x52
   _PICC_MF_AUTH_KEY_A = 0x60
   _PICC_MF_AUTH_KEY_B = 0x61
   _PICC_CT            = 0x88
   _PICC_SEL_CL1       = 0x93
   _PICC_SEL_CL2       = 0x95
   _PICC_SEL_CL3       = 0x97
   _PICC_MF_WRITE      = 0xA0
   _PICC_UL_WRITE      = 0xA2
   _PICC_MF_TRANSFER   = 0xB0
   _PICC_MF_DECREMENT  = 0xC0
   _PICC_MF_INCREMENT  = 0xC1
   _PICC_MF_RESTORE    = 0xC2
   _MAX_BLK = 0xFF
   _AUX_SPI=(1<<8)
   _debug = DBG_OFF
   def __init__(self, pi, channel=SPI_CE0, speed=8e6):
      Instantiate with the Pi to which the card reader is connected.
      Optionally the SPI channel may be specified.  The default is
      main SPI channel 0.
      The following constants may be used to define the channel:
         RC522.SPI_CE0      - main SPI channel 0
         RC522.SPI_CE1      - main SPI channel 1
         RC522.AUX_SPI_CE0  - aux  SPI channel 0
         RC522.AUX_SPI_CE1  - aux  SPI channel 1
         RC522.AUX_SPI_CE2  - aux  SPI channel 2
      Optionally the SPI speed in bps (bits per second) may be
      specified.  The default is 8 Mbps.
      assert SPI_CE0 <= channel <= AUX_SPI_CE2
      assert 32000 <= speed <= 125e6
      self.pi = pi
      if channel < AUX_SPI_CE0:
         self.h = pi.spi_open(channel, int(speed))
      else:
            channel - AUX_SPI_CE0, int(speed), _AUX_SPI)
      self._PCDInit()
   #_util
   def _utilUpdateCrc(self, ch, crc):
      Adds a new byte to the CRC calculation.
      ch = (ch^crc) & 0xFF
      ch = (ch^(ch<<4)) & 0xFF
      crc = (crc >> 8)^(ch << 8)^(ch<<3)^(ch>>4)
      return crc & 0xFFFF
   def _utilComputeCrc(self, data):
      Generates the CRC for the data bytes.
      wCrc = 0x6363 # ITU-V.41
      for ch in data:
         wCrc = self._utilUpdateCrc(ch, wCrc)
      return [wCrc & 0xFF, (wCrc >> 8) & 0xFF]
   # _PCD
   def _PCDWrite(self, reg, val):
      Write val to PCD register reg.
      self.pi.spi_write(self.h, [reg, val])
   def _PCDRead(self, reg):
      Returns the byte read from PCD register reg.
      (c, b) = self.pi.spi_xfer(self.h, [reg|0x80, 0])
      return b[1]
   def _PCDWriteFIFO(self, data):
      Adds data to the PCD FIFO.
      self.pi.spi_write(self.h, [self._FIFODataReg] + data)
   def _PCDReadFIFO(self, count):
      Reads count bytes from the PCD FIFO.
      (c, b) = self.pi.spi_xfer(self.h, [self._FIFODataReg|0x80]*count + [0])
      return list(b[1:])
   def _PCDSetBitMask(self, reg, mask):
      Sets mask bits in PCD register reg.
      tmp = self._PCDRead(reg)
      self._PCDWrite(reg, tmp | mask)
   def _PCDClearBitMask(self, reg, mask):
      Clears mask bits in PCD register reg.
      val = self._PCDRead(reg)
      tmp = val & (~mask)
      if tmp != val:
         self._PCDWrite(reg, tmp)
   def _PCDAntennaOn(self):
      Switches the PCD antenna on.
      temp = self._PCDRead(self._TxControlReg)
      if (temp & 0x03) != 0x03:
         self._PCDSetBitMask(self._TxControlReg, 0x03)
   def _PCDAntennaOff(self):
      Switches the PCD antenna off.
      self._PCDClearBitMask(self._TxControlReg, 0x03)
   def _PCDInit(self):
      Initialises the
      self._RC522SoftReset()
      self._PCDWrite(self._TModeReg,      0x80)
      self._PCDWrite(self._TPrescalerReg, 0xA9)
      self._PCDWrite(self._TReloadRegH,   0x03)
      self._PCDWrite(self._TReloadRegL,   0xe8)
      self._PCDWrite(self._TxASKReg,      0x40)
      #self._PCDWrite(self._ModeReg,       0x3D)
      self._PCDWrite(self._ModeReg,       0x29)
      self._PCDAntennaOn()
   # _RC522
   def _RC522Idle(self):
      Cancel any command in progress.
      self._PCDWrite(self._CommandReg, self._PCD_Idle)
   def _RC522Mem(self, data=None):
      Reads or writes 25 bytes to the PCD internal buffer.
      If data is None the PCD internal buffer is read otherwise
      data is written to the PCD internal buffer.
      self._PCDSetBitMask(self._FIFOLevelReg, 0x80) # Clear FIFO.
      if data is not None:
         self._PCDWriteFIFO(data) # Fill FIFO with data to be written.
         self._PCDWrite(self._CommandReg, self._PCD_Mem)
      else:
         return self._PCDReadFIFO(25)
   def _RC522GenerateRandomID(self):
      Generates a 10 byte random ID and stores it in the PCD internal
      buffer.
      self._PCDWrite(self._CommandReg, self._PCD_GenerateRandomID)
   def _RC522CalcCRC(self, data):
      Generates the CRC for the data bytes using the
      self._PCDWriteFIFO(data) # Fill FIFO with data to be CRC'd .
      self._PCDClearBitMask(self._DivIrqReg, 0x04) # Clear CRC calculated bit.
      self._PCDWrite(self._CommandReg, self._PCD_CalcCRC) # Start CRC.
      timeout = time.time() + 0.1 # 100 milliseconds timeout
      while True:
         n = self._PCDRead(self._DivIrqReg) # Check to see if CRC ready.
         if n & 0x04: # Exit loop if CRC ready.
            break
         if time.time() > timeout:
            return [255, 255]
      return [self._PCDRead(self._CRCResultRegL),
              self._PCDRead(self._CRCResultRegM)]
   def _RC522Transceive(self, cmdData, CRC=True):
      if CRC:
         crc = self._utilComputeCrc(cmdData)
         cmdData += crc
      if self._debug >= DBG_MIN:
         print("_RC522Transceive< {}".format(cmdData))
      irqEn = 0x77
      waitIRq = 0x30
      self._RC522Idle()
      self._PCDWrite(self._ComlEnReg, irqEn|0x80)
      self._PCDWrite(self._CommIrqReg, 0x7F)
      self._PCDWriteFIFO(cmdData) # Fill FIFO with command.
      self._PCDWrite(self._CommandReg, self._PCD_Transceive) # Set command.
      # Start Tranceive command by setting StartSend bit
      self._PCDSetBitMask(self._BitFramingReg, 0x80)
      timeout = time.time() + 0.04 # 40 milliseconds hard timeout
      status = OK
      data = []
      bits = 0
      while True:
         n = self._PCDRead(self._CommIrqReg)
         if n & waitIRq:
            break
         if n & 1:
            status = ERR_TIMEOUT_1
            break
            status = ERR_TIMEOUT_2
            break
      self._PCDClearBitMask(self._BitFramingReg, 0x80)
      if status != OK:
            print("_RC522Transceive> {} {} {}".format(status, data, bits))
         return status, data, bits
      if (self._PCDRead(self._ErrorReg) & 0x1B) == 0x00:
         if n & irqEn & 1:
            status = ERR_NO_TAG
         n = self._PCDRead(self._FIFOLevelReg)
         lastBits = self._PCDRead(self._ControlReg) & 0x07
         if lastBits != 0:
            bits = (n-1)*8 + lastBits
         else:
            bits = n*8
         data = self._PCDReadFIFO(n)
      else:
         status = ERR_UNKNOWN
   def _RC522MFAuthent(self, blockAddr, cmd, key, UID):
      buf = [cmd, blockAddr] + key + UID[:4]
         print("_RC522MFAuthent< {}".format(buf))
      self._RC522Idle()
      self._PCDWriteFIFO(buf) # Fill FIFO with command data.
      self._PCDWrite(self._CommandReg, self._PCD_Authent) # Start command.
      while True:
         n = self._PCDRead(self._Status2Reg)
         if n & 0x08:
            status = OK
            break
         if n & 1:
            break
            break
      if status != OK: # one last try.
         if n & 0x08:
            status = OK
         print("_RC522MFAuthent> {}".format(status))
      return status
   def _RC522SoftReset(self):
      Resets the
      self._PCDWrite(self._CommandReg, self._PCD_SoftReset)
      time.sleep(0.05) # allow 50 milliseconds
   # _MF
   def _MFIncDecRes(self, command,  blockAddr, value):
      A helper function for the increment, decrement, and
      restore value block commands.
      Returns a status (OK on success).
      buf = [command] + [blockAddr]
      (status, data, bits) = self._RC522Transceive(buf)
      if status != OK:
         return status
      buf = [0]*4
      buf[0] =  value      & 0xff
      buf[1] = (value>>8)  & 0xff
      buf[2] = (value>>16) & 0xff
      buf[3] = (value>>24) & 0xff
      status, data, bits = self._RC522Transceive(buf)
      if (status == ERR_TIMEOUT_1) or (status == ERR_TIMEOUT_2):
         status = OK
      return status
   def _MFRead(self, blockAddr):
      Reads a specified block from the card.
      Returns a status (OK on success) and the 16 bytes of the block.
      buf = [self._PICC_MF_READ, blockAddr]
      if bits == 144: # data + CRC
         crc = self._utilComputeCrc(data)
         if crc[0] or crc[1]:
            status = ERR_BAD_CRC
      else:
         status = ERR_BAD_LEN
      return status, data[:16]
   def _MFWrite(self, blockAddr, block):
      Writes 16 bytes to a specified block of the card.
      buf = [self._PICC_MF_WRITE, blockAddr]
      if ((status != OK) or
          (bits != 4) or
          ((data[0] & 0x0F) != 0x0A)):
      if status == OK:
         buf = block[:]
             (bits != 4) or
      return status
   def _MFIncrement(self, blockAddr, val):
      Adds val to the value stored in a value block.
      status = self._MFIncDecRes(self._PICC_MF_INCREMENT, blockAddr, val)
      if status == OK:
         status = self._MFTransfer(blockAddr)
      return status
   def _MFDecrement(self, blockAddr, val):
      Subtracts val from the value stored in a value block.
      status = self._MFIncDecRes(self._PICC_MF_DECREMENT, blockAddr, val)
      if status == OK:
      return status
   def _MFRestore(self, blockAddr):
      Copies a value block from the card to internal volatile memory.
      return self._MFIncDecRes(self._PICC_MF_RESTORE, blockAddr, 0)
   def _MFTransfer(self, blockAddr):
      Copies a value block from internal volatile memory to the card.
      buf = [self._PICC_MF_TRANSFER, blockAddr]
      return status
   # Public
   def ISO_Request(self):
      Checks to see if a card is in range.
      Returns a tuple of status (OK on success) and the cards ATQA.
      self._PCDWrite(self._BitFramingReg, 0x07)
      status, data, bits = self._RC522Transceive([self._PICC_REQA], CRC=False)
      if status != OK:
         ATQA = 0
      else:
         if bits != 16:
            ATQA = 0
         else:
            ATQA = data[0] + (data[1]<<8)
      return status, ATQA
   def ISO_Anticollision(self):
      Deselects all but one card in range.
      Returns a tuple of status (OK on success) and the UID of the
      active card in range.
      command = [self._PICC_SEL_CL1, 0x20]
      self._PCDWrite(self._BitFramingReg, 0x00)
      status, data, bits = self._RC522Transceive(command, CRC=False)
      if status == OK:
         i = 0
         if len(data) == 5:
            uidCheck = 0
            while i<4:
               uidCheck = uidCheck ^ data[i]
               i += 1
            if uidCheck != data[i]:
         else:
      return status, data
   def ISO_Select(self, UID):
      Selects the active tag in range by its UID (including the BCC
      byte).
      Returns a tuple of status (OK on success) and the cards SAK.
      assert len(UID) == 5
      buf = [self._PICC_SEL_CL1, 0x70] + UID
      if (status == OK) and (bits == 24):
         return OK, data[0]
      else:
         return ERR_UNKNOWN, 0
   def ISO_Authenticate(self, blockAddr, keyId, key, UID):
      Authenticates access to a block.
      The keyId must be one of the constants:
         KEY_A
         KEY_B
      assert 0 <= blockAddr <= PCD._MAX_BLK
      assert KEY_A <= keyId <= KEY_B
      assert len(key) == 6
      assert 4 <= len(UID) <= 5
      if keyId == KEY_A:
         cmd = self._PICC_MF_AUTH_KEY_A
      else:
         cmd = self._PICC_MF_AUTH_KEY_B
      return self._RC522MFAuthent(blockAddr, cmd, key, UID)
   def ISO_StopCrypto(self):
      Releases a card.
      self._PCDClearBitMask(self._Status2Reg, 0x08)
   def MF_ReadBlock(self, blockAddr):
      Reads a block from the card.
      Returns a tuple of status (OK on success) and the 16-byte block.
      return self._MFRead(blockAddr)
   def MF_WriteBlock(self, blockAddr, block):
      Writes a block to the card.
      assert len(block) == 16
      return self._MFWrite(blockAddr, block)
   def MF_IncrementBlock(self, blockAddr, val):
      assert val >= 0
      return self._MFIncrement(blockAddr, val)
   def MF_DecrementBlock(self, blockAddr, val):
      assert val >= 0
      return self._MFDecrement(blockAddr, val)
   def MF_RestoreBlock(self, blockAddr):
      Reads a value block into card volatile memory.
      return self._MFRestore(blockAddr)
   def MF_TransferBlock(self, blockAddr):
      Writes a value block from card volatile memory.
      return self._MFTransfer(blockAddr)
   def MF_SetValue(self, blockAddr, val):
      Formats a block as a value block with the value val and
      writes the block to the card.
      assert val >= 0
      blk = [0]*16
      blk[0] = (val &       0xFF)
      blk[1] = (val &     0xFF00) >> 8
      blk[2] = (val &   0xFF0000) >> 16
      blk[3] = (val & 0xFF000000) >> 24
      blk[8] = blk[0]
      blk[9] = blk[1]
      blk[10] = blk[2]
      blk[11] = blk[3]
      blk[4] = ~blk[0]&0xFF
      blk[5] = ~blk[1]&0xFF
      blk[6] = ~blk[2]&0xFF
      blk[7] = ~blk[3]&0xFF
      blk[12] = blockAddr
      blk[13] = ~blockAddr&0xFF
      blk[14] = blockAddr
      blk[15] = ~blockAddr&0xFF
      return self._MFWrite(blockAddr, blk)
   def MF_GetValue(self, blockAddr):
      Reads a value block from the card and returns its value
      (this function assumes the block is a valid value block).
      Returns a tuple of status (OK on success) and the 32-bit value.
      status, data = self._MFRead(blockAddr)
      if status == OK:
         value = data[3]<<24 | data[2]<<16 | data[1]<<8 | data[0]
      else:
         value = 0
      return status, value
   def Util_JoinAccessBits(self, b0, b1, b2, st):
      Constructs the access bits needed for a combination
      of block and sector trailer permissions.
      b0-b2 define the permissions for data blocks 0-2 of the
      sector according to the following table:
         R    W    I    DTR
      0  AB   AB   AB   AB  value (default)
      1  AB   -    -    AB  value
      2  AB   -    -    -   data
      3  B    B    -    -   data
      4  AB   B    -    -   data
      5  B    -    -    -   data
      6  AB   B    B    AB  value
      7  -    -    -    -
      st defines the permissions for the sector trailer of the
          KeyA   Access   KeyB
          R  W   R    W   R  W
      0   -  A   A    -   A  A
      1   -  A   A    A   A  A (default)
      2   -  -   A    -   A  -
      3   -  B   AB   B   -  B
      4   -  B   AB   -   -  B
      5   -  -   AB   B   -  -
      6   -  -   AB   -   -  -
      7   -  -   AB   -   -  -
      assert 0 <= b0 <= 7
      assert 0 <= b1 <= 7
      assert 0 <= b2 <= 7
      assert 0 <= st <= 7
      c1 = ((st&4) << 1) | ((b2&4) << 0) | ((b1&4) >> 1) | ((b0&4) >> 2)
      c2 = ((st&2) << 2) | ((b2&2) << 1) | ((b1&2) << 0) | ((b0&2) >> 1)
      c3 = ((st&1) << 3) | ((b2&1) << 2) | ((b1&1) << 1) | ((b0&1) << 0)
      ab0 = (~c2 & 0xF) << 4 | (~c1 & 0xF)
      ab1 =          c1 << 4 | (~c3 & 0xF)
      ab2 =          c3 << 4 | c2
      return [ab0, ab1, ab2]
   def Util_SplitAccessBits(self, accessBits):
      Converts the three access bits bytes of the sector trailer to
      the individual permissions for each block of the sector.
      permissions for blocks 0, 1, 2, and 3 of the sector.
      assert len(accessBits) == 3
      c1  = accessBits[1] >> 4
      c2  = accessBits[2] & 0xF
      c3  = accessBits[2] >> 4
      c1_ = accessBits[0] & 0xF
      c2_ = accessBits[0] >> 4
      c3_ = accessBits[1] & 0xF
      b0 = ((c1 & 1) << 2) | ((c2 & 1) << 1) | ((c3 & 1) << 0);
      b1 = ((c1 & 2) << 1) | ((c2 & 2) << 0) | ((c3 & 2) >> 1);
      b2 = ((c1 & 4) << 0) | ((c2 & 4) >> 1) | ((c3 & 4) >> 2);
      st = ((c1 & 8) >> 1) | ((c2 & 8) >> 2) | ((c3 & 8) >> 3);
      if (c1 == (~c1_&0xF)) and (c2 == (~c2_&0xF)) and (c3 == (~c3_&0xF)):
         status = OK
      else:
         status = ERR_BAD_ACCESS_BITS
      return status, b0, b1, b2, st
   def Util_JoinSectorTrailer(self, keyA, keyB, accessBits, GPB):
      Returns a 16-byte sector trailer formed from key A, key B,
      the access bits, and the GPB (General Purpose Byte).
      assert len(keyA) == 6
      assert len(keyB) == 6
      assert 0 <= GPB <= 255
      return keyA + accessBits + [GPB] + keyB
   def Util_SplitSectorTrailer(self, block):
      Takes a 16 byte sector trailer and returns a tuple of
         key A                          - bytes 0-5
         key B                          - bytes 10-15
         the access bits                - bytes 6-8
         the GPB (General Purpose Byte) - byte 9
      If the block was read from the card Key A will always be all
      zeros.
      return block[0:6], block[10:16], block[6:9], block[9]
   def Util_RC522ReadMem(self):
      Returns the 25-byte PCD internal buffer.
      return self._RC522Mem()
   def Util_RC522WriteMem(data):
      Writes the 25-byte PCD internal buffer.
      assert len(data) == 25
      self._RC522Mem(data)
   def Util_RC522GenerateRandomID(self):
      Returns a PCD generated 10-byte random ID.
      self._RC522GenerateRandomID() # Generate the random ID.
      data = self._RC522Mem() # Read internal buffer.
      return data[2:5] + data[8:14] + [data[24]]
   def Util_SetDebugLevel(self, level):
      This function enables or disables internal debug diagnostics.
      The level may be one of the constants:
         DBG_OFF
         DBG_MIN
         DBG_MAX
      assert DBG_OFF <= level <= DBG_MAX
      self._debug = level
   def stop(self):
      Closes the connection to the
      self._PCDAntennaOff()
      self.pi.spi_close(self.h)
Here is a test script (just authenticates against the default keys and reads a sector).
import time
import pigpio
def key2str(key):
   return "".join("{:02X}".format(c) for c in key)
def str2key(keystr):
   return [int(keystr[x:x+2],16) for x in range(0,12,2)]
def generateKey():
   k = os.urandom(6)
   key = []
   for c in k:
      key.append(ord(c))
   return key2str(key)
STB=7
def card_present(obj):
   ATQA=0
   UID=[]
   SAK=0
   status = RC522.ERR_NO_TAG
   timeout = time.time() + 5
   while status != RC522.OK and time.time() < timeout:
      obj.ISO_StopCrypto()
      status, ATQA = obj.ISO_Request()
      if status == RC522.OK:
         print("Card request, ATQA={}".format(ATQA))
         status, UID = obj.ISO_Anticollision() # Get the UID of the card
            print("Card anticollision, UID=[{}, {}, {}, {}]".
               format(UID[0], UID[1], UID[2], UID[3]))
            status, SAK = obj.ISO_Select(UID)
               print("Card select, SAK={}".format(SAK))
            else:
               print("Card select failed,")
         else:
            print("Card anticollision failed,")
      else:
         print("Card request failed,")
   return status, ATQA, UID, SAK
def card_wipe(obj, keyA):
   keyD = [255]*6
   blockD = [0]*16
   status, ATQA, UID, SAK = card_present(obj)
      # Authenticate sector trailer
      status = obj.ISO_Authenticate(STB, RC522.KEY_A, keyA, UID)
      if status == RC522.OK: # Check if authenticated.
         print("authenticated with key A")
         # Set default keys and access bits.
         AB = obj.Util_JoinAccessBits(0, 0, 0, 1)
         block = obj.Util_JoinSectorTrailer(keyD, keyD, AB, 0)
         status = obj.MF_WriteBlock(STB, block)
            print("new st written okay")
            # Authenticate sector trailer against default keys
            status = obj.ISO_Authenticate(STB, RC522.KEY_A, keyD, UID)
               for i in range(STB-3, STB):
                  status = obj.MF_WriteBlock(i, blockD)
                     print("block {} cleared ok".format(i))
                  else:
                     print("*** block {} not cleared ok".format(i))
            else:
               print("*** authentication error with default keys")
         else:
            print("*** write ST failed with old keys")
      else:
         print("*** authentication error with old keys")
   else:
      print("*** card not present")
   return status
def card_read_AB(obj, keyA, keyB):
   answer = ""
         print("authenticated sector trailer with key A")
         status, block = obj.MF_ReadBlock(STB)
         answer = str(block)
         print(block)
         status = obj.ISO_Authenticate(STB-3, RC522.KEY_B, keyB, UID)
            print("authenticated data blocks with key B")
               status, block = obj.MF_ReadBlock(i)
               answer += "\n" + str(block)
               print(block)
         else:
            print("*** authentication error with key B")
      else:
         print("*** authentication error with key A")
   else:
   return status, answer
def card_read_B(obj, keyB):
   answer = ""
         s1, v1 = obj.MF_GetValue(STB-3)
         s2, v2 = obj.MF_GetValue(STB-2)
         s3, v3 = obj.MF_GetValue(STB-1)
         answer = "{}:{}\n{}:{}\n{}:{}".format(s1,v1,s2,v2,s3,v3)
         if s1 == RC522.OK and s2 == RC522.OK and s3 == RC522.OK:
            print("blocks read ok")
         else:
            print("*** blocks not read ok")
      else:
   else:
def card_personalise(obj, keyA, keyB, val1, val2, val3):
   keyD = [255]*6
   blockD = [0]*16
      # Authenticate sector trailer with default key
         print("authenticated with default key")
         s1 = obj.MF_SetValue(STB-3, val1)
         s2 = obj.MF_SetValue(STB-2, val2)
         s3 = obj.MF_SetValue(STB-1, val3)
            print("blocks written ok")
         else:
            print("*** blocks not written ok")
         # Set new keys and access bits.
         AB = obj.Util_JoinAccessBits(5, 3, 6, 1)
         block = obj.Util_JoinSectorTrailer(keyA, keyB, AB, 0)
         else:
            print("*** write ST failed with default keys")
      else:
   else:
   return status
import pigpio
import RC522
pi = pigpio.pi()
if not pi.connected:
   exit()
keyA=[255]*6 # Default key A.
keyB=[255]*6 # Default key B.
cr = RC522.PCD(pi, 0, 50e3) # SPI channel 0
card_read_AB(cr, keyA, keyB)
print("exiting")
cr.stop()
pi.stop()
Both are work in progress.
Posted: Fri Feb 17, 2017 9:42 pm
by mattlewis
That's excellent, really appreciated. Looks like we're at a similar point but you've done a heck of a lot more research hence have a much cleaner implementation.
Are you ok if I refactor my code a bit to match yours? I'll be sure to give you credit.
Matt
Posted: Fri Feb 17, 2017 9:54 pm
by joan
mattlewis wrote:That's excellent, really appreciated. Looks like we're at a similar point but you've done a heck of a lot more research hence have a much cleaner implementation.
Matt
Do what you want with the code, no need for credit. When I'm happy with it I would have marked it Public Domain.
Posted: Wed Jun 07, 2017 7:29 pm
by mattlewis
FYI I've got this fully working now, ported the Arduino library to Java in my diozero library.
Posted: Wed Jul 05, 2017 8:50 pm
by mattlewis
