I have an JavaFX application that runs perfectly on a normal desktop. I am trying to make it run on a Raspberry Pi 2 (1GB) but I am not able to. I really need some help because I need to use the PI to deploy this application to some costumers.
These are the details and error messages:
Raspberry Pi 2 B
java version "1.8.0"
Java(TM) SE Runtime Environment (build 1.8.0-b132)
Java HotSpot(TM) Client VM (build 25.0-b70, mixed mode)
ERRORS:
pi@raspberrypi ~ $ java -jar KangarooAdmin.jar
java.lang.ClassNotFoundException: com.sun.deploy.uitoolkit.impl.fx.HostServicesFactory
at java.net.URLClassLoader$1.run(URLClassLoader.java:372)
at java.net.URLClassLoader$1.run(URLClassLoader.java:361)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:360)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:340)
at com.sun.javafx.application.HostServicesDelegate$1.run(HostServicesDelegate.java:57)
at com.sun.javafx.application.HostServicesDelegate$1.run(HostServicesDelegate.java:46)
at com.sun.javafx.application.HostServicesDelegate.getInstance(HostServicesDelegate.java:45)
at javafx.application.HostServices.<init>(HostServices.java:52)
at javafx.application.Application.getHostServices(Application.java:323)
at kangarooadmin.KangarooAdmin.start(KangarooAdmin.java:58)
at com.sun.javafx.application.LauncherImpl$8.run(LauncherImpl.java:837)
at com.sun.javafx.application.PlatformImpl$7.run(PlatformImpl.java:335)
at com.sun.javafx.application.PlatformImpl$6$1.run(PlatformImpl.java:301)
at com.sun.javafx.application.PlatformImpl$6$1.run(PlatformImpl.java:298)
at com.sun.javafx.application.PlatformImpl$6.run(PlatformImpl.java:298)
at com.sun.glass.ui.lens.LensApplication$RunnableEvent.dispatch(LensApplication.java:182)
at com.sun.glass.ui.lens.LensApplication._runLoop(LensApplication.java:860)
at com.sun.glass.ui.lens.LensApplication.access$1800(LensApplication.java:58)
at com.sun.glass.ui.lens.LensApplication$4.run(LensApplication.java:917)
at java.lang.Thread.run(Thread.java:744)
Exception in Application start method
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:483)
at com.sun.javafx.application.LauncherImpl.launchApplicationWithArgs(LauncherImpl.java:367)
at com.sun.javafx.application.LauncherImpl.launchApplication(LauncherImpl.java:305)
at sun.launcher.LauncherHelper$FXHelper.main(LauncherHelper.java:767)
Caused by: java.lang.RuntimeException: Exception in Application start method
at com.sun.javafx.application.LauncherImpl.launchApplication1(LauncherImpl.java:894)
at com.sun.javafx.application.LauncherImpl.access$000(LauncherImpl.java:56)
at com.sun.javafx.application.LauncherImpl$1.run(LauncherImpl.java:158)
Caused by: java.lang.NullPointerException
at javafx.application.HostServices.getCodeBase(HostServices.java:67)
... 1 more
Exception running application kangarooadmin.KangarooAdmin
