mgoes
Could not initialize class gnu.io.CommPortIdentifier on tomc
Fri Mar 06, 2015 4:03 am
I have Java installed by
sudo apt-get install oracle-java8-jdk
and rxtx installed by
sudo apt-get install librxtx-java
When I execute as a standard application, like this:
java -Djava.library.path=/usr/lib/jni -cp /usr/share/java/RXTXcomm.jar:. -jar myApp.jar
it works without errors. But when I try to execute as a web application, a get the error mentioned in the title. That web application is working fine on OSX.I just created the war file and dropped it on raspberry's Tomcat webapps folder.
A strange thing is that, if I dont run the standard application before, I says "no rxtxSerial in java.library.path", instead what I mentioned before.
precious_pony
Re: Could not initialize class gnu.io.CommPortIdentifier on
Fri Mar 06, 2015 4:54 pm
It is likely that you have to add the additional java library path the web application server (e.g. jetty or tomcat ).
For Jetty
Edit either :
/etc/default/jetty
or
/etc/init.d/jetty
and you are looking at the JAVA_OPTIONS section.
For Tomcat:
This answer on stack overflow might help.
mgoes
Fri Mar 06, 2015 5:14 pm
I have already seem that post on stack overflow. It didn't worked for me.
I tried to change from oracles's jdk to openjdk-7. But now I get "Unsupported major.minor version 52". It was compiled on jdk8. So I know the reason for that is the version of the compiler. Is openjdk-8 is available for raspbian?
mgoes
Fri Mar 06, 2015 11:45 pm
I did some modifications on my server, now I getting this message:
org.apache.jasper.JasperException: An exception occurred processing JSP page /index.jsp at line 41
38: <form name="Name Input Form" action="controlServlet" method="POST">
39: <label>Selecione a porta serial:</label>
40: <%
41: Enumeration pList = CommPortIdentifier.getPortIdentifiers();
42: ArrayList<String> p = new ArrayList<>();
43:
44: // Process the list.
I thought it could be caused by unresolved dependencies. The CommPortIdentifier class is located in RXTXcomm.jar, so I went to /usr/share/java/lib, copied RXTXcomm.jar and paste in [tomcat home]/webapps/myApp/WEB-INF/lib. It didn't work, its just the same.
Anybody knows what to do next?
Sat Mar 07, 2015 9:58 am
mgoes
Sat Mar 07, 2015 10:37 pm
I installed RXTX by
. Ins't it enough?
bullen
Sun Mar 08, 2015 8:28 am
-cp and -jar don't work well together.
Try: java -Djava.library.path=/usr/lib/jni -cp /usr/share/java/RXTXcomm.jar:myApp.jar path.to.the.main.Class
Also if you wan't HTTP hot-deploy take a look at this.
https://github.com/tinspin/rupy - A tiny Java async HTTP application server.
knute
Mon Mar 09, 2015 3:19 am
The -cp option is ignored if -jar is specified.
-jar filename
    Executes a program encapsulated in a JAR file. The filename argument is the name of a JAR file with a manifest that contains a line in the form Main-Class:classname that defines the class with the public static void main(String[] args) method that serves as your application's starting point.
    When you use the -jar option, the specified JAR file is the source of all user classes, and other class path settings are ignored.
Return to “Java”
