TheSenate
64-bit Java on RPi4
Thu Jun 18, 2020 2:32 am
So I'm trying to run Minecraft server for my friends and I to use. I have a Raspberry Pi 4B with 8GB RAM, and I want to dedicate 4 out of the 8 gigs to the server. When I try to do so, the Java output is:
Invalid maximum heap size: -Xmx4G
The specified size exceeds the maximum representable size.
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit.
I'm assuming this is because the installed version of Java is 32-bit, which is limiting the maximum amount of memory available to the VM. I followed the instructions at viewtopic.php?t=250730 to use the 64-bit kernel, but I'm unsure of how to use a 64-bit installation of Java. Any help would be much appreciated.
Re: 64-bit Java on RPi4
Thu Jun 18, 2020 8:07 am
RaspiOS ARMHF is by default 32bit Kernel and 32bit Userland, changing to the 64bit Kernel it is 64bit Kernel and 32bit Userland.
There is now a a testing version of RaspiOS ARM64 which is 64bit Kernel and 64bit Userland
http://downloads.raspberrypi.org/raspio ... 020-05-28/
My other Linux machine is a ChromeBox
TheSenate
Thu Jun 18, 2020 11:49 am
Wow, sounds promising. So would that let me create the 4GB JVM? Also, is there anything I have to do with my installation of Java (right now, I have default-jdk installed).
bullen
Tue Jul 21, 2020 1:26 pm
I'm struggling with this too, I tried downloading Linux ARM 64 Hard Float ABI: https://www.oracle.com/java/technologie ... loads.html
But it gives HeadlessException!
Where can we find 64-bit Java?
Edit: found it, sudo apt-get install openjdk-11-jdk
https://github.com/tinspin/rupy - A tiny Java async HTTP application server.
knute
Tue Jul 21, 2020 10:43 pm
bell-sw.com
msk
Wed Jan 13, 2021 10:46 am
bullen,
I am also trying to install 64 bit java on RPi4, may I know the OS details on which your able to install 64 bit java?
I tried install java 64 bit on raspberry pi 32 bit version, but it failing with error package not found.
Wed Jan 13, 2021 1:07 pm
bullen,
You can run Raspberry Pi ARM64 Beta Operating System, and install openjdk from the repositories:
http://downloads.raspberrypi.org/raspio ... 020-08-24/
After install you will need a full upgrade:
sudo apt update
sudo apt full-upgrade
sudo reboot
The ARM64 release is based of Debian Buster ARM64 and therefore 64bit kernel and userland.
Return to “Java”
