Karol_K_pl
Why JavaFX (3D) on Raspberry Pi doesn't work completely , although it should? (Solved)
Sat Jul 20, 2019 9:37 am
Hello dear community of RPi :) as I'm new here I'd like make some small introduction. I'm also brand new user of RPi and also stil learning programming in Java. As a newbie I'm trying to do some my own projects to practice Java, JavaFX and Raspberry coding. Ma latest goal which I set for myself is 3D visualization of force from tensometric beam. I managed to achieve simple chart and and simple visualization of actual pressure force (in circle). (https://imagizer.imageshack.com/img922/2663/spBwMs.gif) Now I'd like to represent it as 3D bars. I've done some initial work but I encountered some problems. I wrote some post about it on Stack Overflow, can you look at it, please ? Maybe someone can give me some more advice?
https://stackoverflow.com/questions/571 ... -it-should
Karol.
Karol_K_pl
Re: Why JavaFX (3D) on Raspberry Pi doesn't work completely , although it should?
Mon Jul 22, 2019 2:05 am
So I found the solution. I put the answer in Stack Overflow forum.
knute
Mon Jul 22, 2019 6:30 pm
Is this on a Pi 3 or 4?
thanks!
Karol_K_pl
Mon Jul 22, 2019 8:34 pm
Right, I didn't mention about it, raspberry pi 3 b+
Return to “Java”
