clicky
Compiling Eclipse on Pi (Pi4?)
Fri Jul 05, 2019 12:48 pm
Hi all,
I would like to start this discussion about Eclipse and Pi.
Now we have Pi4 and it getting close to a 'desktop computer' it would only be fitting to have appropriate (alternative) of Java IDE. I am aware that 'eclipse' (and 'eclipse-jdt') is available through standard Raspbian repos, but it is 3.8 (the latest is 4.12) and not upgradeable (there are some issues with repo setup).
I've tried to trawl the internet for anything else but failed. Only thing I found is source from where that 3.8 (I think) version came from: https://github.com/turesheim/eclipse-rpi.git
Following that I found this: https://git.eclipse.org/c/ and from there https://git.eclipse.org/c/platform/ecli ... gator.git/
I've played a bit with Torkild's script and tried to build newer versions - starting from R4_4 (which cannot be built due to being too old and pointing to non-existent repos) R4_12 (which doesn't have arm support any more) and ending up with R4_11 and failed.
I've tried to build it just through maven directly and I tried to build 'arm' (native) version and each time it would fail in different way. I tried to remedy some of the errors but not really managed to get anywhere.
Last thing I did was this: https://www.eclipse.org/forums/index.php/t/1099602/ (fingers crossed)
So, any ideas, pointers, previous experience or anything you can add regarding this subject - please post here :)
Re: Compiling Eclipse on Pi (Pi4?)
Fri Jul 05, 2019 12:53 pm
My pointer is that I have given up trying to do this. The Eclipse build is a total mess. Debian are/were thinking of dropping it entirely from their repos because it's almost impossible to build.
If you do succeed - note down how you did it!
clicky
Fri Jul 05, 2019 1:05 pm
I get it - there's quite a lot of 'hidden knowledge' buried there - somewhere.
BTW I am trying - this is the latest: https://github.com/turesheim/eclipse-rpi/issues/4
jamesh wrote: If you do succeed - note down how you did it!
Huh - of course. It is really hard to track going blind through options - especially when you're determined to do it. So many dead-ends and backtracking, etc. But, if nothing else if I (or someone else!) succeed in it - at least we'll know it is possible and I am happy to give it a go again (or assist anyone wanting to do so).
Also, it would be nice, then, propagating it further to the distro or something...
clicky
Sat Jul 06, 2019 1:46 pm
OK. I moved from square one - I managed to create .so files in org.eclipse.swt.gtk.linux.arm of R4_11_maintenance branch.
Now, it is really proper bodge I end up with - manually finding build file, moving folders around, installing randomly 'stuff', etc...
But result is in:
libswt-atk-gtk-4924r25.so
libswt-cairo-gtk-4924r25.so
libswt-glx-gtk-4924r25.so
libswt-gtk-4924r25.so
libswt-pi3-gtk-4924r25.so
libswt-webkit-gtk-4924r25.so
Full output:
-e Cairo found, compiling SWT support for the cairo graphics library.
-e *** libjawt.so not found, the SWT/AWT integration library will not be compiled.
-e Building SWT/GTK+ for Architectures: linux armv7l
build.sh: 332: [: 1: unexpected operator
-e *** Warning: Cannot compile Webkit2 Extension because 'pkg-config --exists webkit2gtk-web-extension-4-0' check failed. Please install webkitgtk4-devel.ARCH on your system.
-e Building GTK3 bindings:
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux  -c swt.c
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux    -c -o c.o c.c
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux    -c -o c_stats.o c_stats.c
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux  -DUSE_ASSEMBLER -c callback.c
cc -shared -fPIC  -s -o libswt-gtk-4924r25.so swt.o c.o c_stats.o callback.o
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux  `pkg-config --cflags gtk+-3.0 gtk+-unix-print-3.0` -c os.c
os.c: In function ‘Java_org_eclipse_swt_internal_gtk_GDK__1gdk_1window_1set_1background_1pattern’:
os.c:2973:2: warning: ‘gdk_window_set_background_pattern’ is deprecated [-Wdeprecated-declarations]
  gdk_window_set_background_pattern((GdkWindow *)arg0, (cairo_pattern_t *)arg1);
In file included from /usr/include/gtk-3.0/gdk/gdkseat.h:28,
                 from /usr/include/gtk-3.0/gdk/gdkdisplay.h:33,
                 from /usr/include/gtk-3.0/gdk/gdkscreen.h:32,
                 from /usr/include/gtk-3.0/gdk/gdkapplaunchcontext.h:31,
                 from /usr/include/gtk-3.0/gdk/gdk.h:32,
                 from /usr/include/gtk-3.0/gtk/gtk.h:30,
                 from os.h:30,
                 from os_structs.h:19,
                 from os.c:20:
/usr/include/gtk-3.0/gdk/gdkwindow.h:790:12: note: declared here
 void       gdk_window_set_background_pattern (GdkWindow  *window,
os.c: In function ‘Java_org_eclipse_swt_internal_gtk_GDK_gdk_1threads_1leave’:
os.c:3243:2: warning: ‘gdk_threads_leave’ is deprecated [-Wdeprecated-declarations]
  gdk_threads_leave();
In file included from /usr/include/gtk-3.0/gdk/gdk.h:61,
                 from os.h:30,
                 from os.c:20:
/usr/include/gtk-3.0/gdk/gdkthreads.h:48:10: note: declared here
 void     gdk_threads_leave                    (void);
os.c: In function ‘Java_org_eclipse_swt_internal_gtk_GTK__1gtk_1status_1icon_1get_1geometry’:
os.c:9266:2: warning: ‘gtk_status_icon_get_geometry’ is deprecated [-Wdeprecated-declarations]
  rc = (jboolean)gtk_status_icon_get_geometry((GtkStatusIcon*)arg0, (GdkScreen**)arg1, (GdkRectangle*)lparg2, (GtkOrientation*)arg3);
In file included from /usr/include/gtk-3.0/gtk/gtk.h:275,
                 from os.h:30,
                 from os.c:20:
/usr/include/gtk-3.0/gtk/deprecated/gtkstatusicon.h:166:23: note: declared here
 gboolean              gtk_status_icon_get_geometry       (GtkStatusIcon      *status_icon,
os.c: In function ‘Java_org_eclipse_swt_internal_gtk_GTK__1gtk_1status_1icon_1get_1visible’:
os.c:9280:2: warning: ‘gtk_status_icon_get_visible’ is deprecated [-Wdeprecated-declarations]
  rc = (jboolean)gtk_status_icon_get_visible((GtkStatusIcon*)arg0);
                 from os.h:30,
                 from os.c:20:
/usr/include/gtk-3.0/gtk/deprecated/gtkstatusicon.h:154:23: note: declared here
 gboolean              gtk_status_icon_get_visible        (GtkStatusIcon      *status_icon);
os.c: In function ‘Java_org_eclipse_swt_internal_gtk_GTK__1gtk_1status_1icon_1new’:
os.c:9292:2: warning: ‘gtk_status_icon_new’ is deprecated [-Wdeprecated-declarations]
  rc = (jintLong)gtk_status_icon_new();
                 from os.h:30,
                 from os.c:20:
/usr/include/gtk-3.0/gtk/deprecated/gtkstatusicon.h:84:23: note: declared here
 GtkStatusIcon        *gtk_status_icon_new                (void);
os.c: In function ‘Java_org_eclipse_swt_internal_gtk_GTK__1gtk_1status_1icon_1set_1from_1pixbuf’:
os.c:9315:2: warning: ‘gtk_status_icon_set_from_pixbuf’ is deprecated [-Wdeprecated-declarations]
  gtk_status_icon_set_from_pixbuf((GtkStatusIcon*)arg0, (GdkPixbuf*)arg1);
                 from os.h:30,
                 from os.c:20:
/usr/include/gtk-3.0/gtk/deprecated/gtkstatusicon.h:97:23: note: declared here
 void                  gtk_status_icon_set_from_pixbuf    (GtkStatusIcon      *status_icon,
os.c: In function ‘Java_org_eclipse_swt_internal_gtk_GTK__1gtk_1status_1icon_1set_1tooltip_1text’:
os.c:9327:2: warning: ‘gtk_status_icon_set_tooltip_text’ is deprecated [-Wdeprecated-declarations]
  gtk_status_icon_set_tooltip_text((GtkStatusIcon *)arg0, (const gchar *)lparg1);
                 from os.h:30,
                 from os.c:20:
/usr/include/gtk-3.0/gtk/deprecated/gtkstatusicon.h:137:23: note: declared here
 void                  gtk_status_icon_set_tooltip_text   (GtkStatusIcon      *status_icon,
os.c: In function ‘Java_org_eclipse_swt_internal_gtk_GTK__1gtk_1status_1icon_1set_1visible’:
os.c:9339:2: warning: ‘gtk_status_icon_set_visible’ is deprecated [-Wdeprecated-declarations]
  gtk_status_icon_set_visible((GtkStatusIcon*)arg0, (gboolean)arg1);
                 from os.h:30,
                 from os.c:20:
/usr/include/gtk-3.0/gtk/deprecated/gtkstatusicon.h:151:23: note: declared here
 void                  gtk_status_icon_set_visible        (GtkStatusIcon      *status_icon,
os.c: In function ‘Java_org_eclipse_swt_internal_gtk_OS__1g_1variant_1n_1children’:
os.c:16970:35: warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
  rc = (jlong)g_variant_n_children((GVariant *)arg0);
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux  `pkg-config --cflags gtk+-3.0 gtk+-unix-print-3.0` -c os_structs.c
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux  `pkg-config --cflags gtk+-3.0 gtk+-unix-print-3.0` -c os_custom.c
os_custom.c: In function ‘swt_fixed_realize’:
os_custom.c:500:3: warning: ‘gtk_style_context_set_background’ is deprecated: Use 'gtk_render_background' instead [-Wdeprecated-declarations]
   gtk_style_context_set_background (gtk_widget_get_style_context (widget), window);
In file included from /usr/include/gtk-3.0/gtk/gtkicontheme.h:27,
                 from /usr/include/gtk-3.0/gtk/gtk.h:127,
                 from os.h:30,
                 from os_custom.c:17:
/usr/include/gtk-3.0/gtk/gtkstylecontext.h:1232:6: note: declared here
 void gtk_style_context_set_background       (GtkStyleContext *context,
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux  `pkg-config --cflags gtk+-3.0 gtk+-unix-print-3.0` -c os_stats.c
cc -shared -fPIC  -s -o libswt-pi3-gtk-4924r25.so swt.o os.o os_structs.o os_custom.o os_stats.o `pkg-config --libs-only-L gtk+-3.0 gthread-2.0`  -L/usr/X11R6/lib -lgtk-3 -lgdk-3 -lcairo -lgthread-2.0
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux  `pkg-config --cflags atk gtk+-3.0 gtk+-unix-print-3.0` -c atk.c
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux  `pkg-config --cflags atk gtk+-3.0 gtk+-unix-print-3.0` -c atk_structs.c
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux  `pkg-config --cflags atk gtk+-3.0 gtk+-unix-print-3.0` -c atk_custom.c
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux  `pkg-config --cflags atk gtk+-3.0 gtk+-unix-print-3.0` -c atk_stats.c
cc -shared -fPIC  -s -o libswt-atk-gtk-4924r25.so swt.o atk.o atk_structs.o atk_custom.o atk_stats.o `pkg-config --libs-only-L atk` -latk-1.0
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux   -c glx.c
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux   -c glx_structs.c
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux   -c glx_stats.c
cc -shared -fPIC  -s -o libswt-glx-gtk-4924r25.so swt.o glx.o glx_structs.o glx_stats.o -lGL -lGLU -lm
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux  `pkg-config --cflags gio-2.0` -c webkitgtk.c
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux  `pkg-config --cflags gio-2.0` -c webkitgtk_structs.c
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux  `pkg-config --cflags gio-2.0` -c webkitgtk_stats.c
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux  `pkg-config --cflags gio-2.0` -c webkitgtk_custom.c
cc -shared -fPIC  -s -o libswt-webkit-gtk-4924r25.so swt.o webkitgtk.o webkitgtk_structs.o webkitgtk_stats.o webkitgtk_custom.o `pkg-config --libs-only-l gio-2.0`
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux  `pkg-config --cflags cairo` -c cairo.c
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux  `pkg-config --cflags cairo` -c cairo_structs.c
cc -O -Wall -fPIC -DSWT_VERSION=4924r25    -DLINUX -DGTK -I/usr/lib/jvm/current//include -I/usr/lib/jvm/current//include/linux  `pkg-config --cflags cairo` -c cairo_stats.c
cc -shared -fPIC  -s -o libswt-cairo-gtk-4924r25.so swt.o cairo.o cairo_structs.o cairo_stats.o `pkg-config --libs-only-L cairo` -lcairo
-e GTK3 Build succeeded
I really wish I have someone beside me who understands 'things' to help:
- why that build script is not invoked by ant
- what we really need for first error ("Please install webkitgtk4-devel.ARCH on your system") or is it just a red herring
- if I have .so files what then! (only thing I can think of is get some zip file distribution of eclipse for linux and replace existing .so files in there with those I created and hope for the best)
- do I need to build some other c files somewhere else (I'm sure that there are other places where c files exist)
Also, I'm aware that some of those questions really need to be posted at Eclipse people - but so far I've not no response over there...
clicky
Sun Jul 07, 2019 7:13 pm
This is interesting:
- compiling R4_11_maintenance branch on Mac and RPi - fails!
- compiling R4_12_maintenance branch on Mac succeeds but fails on RPi
Difference between Mac and RPi are:
RPi: Java 1.8.0_211, mvn 3.6.0
Mac: Java 1.8.0_111, mvn 3.6.1
(I don't think that's what causes it to fail)
Now - I'll just try to compile .so files (and main 'eclipse' executable) on the same version on RPi and replace them in x86_64 build to try it out...
clicky
Sun Jul 07, 2019 8:38 pm
Some progress:
jachaney
Mon Jul 08, 2019 8:31 pm
I actually have been running Eclipse on my 3B+. Some features run a little slow but for the most part it works just great. The problem I had was switching to Raspbian v3.1.1(new Buster). The new Java causes the load version of Eclipse to crash at startup. Not happy with the twiddling Oracle has been doing to Java. Going to wait for the apt update for Eclipse to catch up I guess.
clicky
Tue Jul 09, 2019 6:34 am
Which version of Eclipse? If it is one supplied by Raspbian repos (3.8) it is way too old. It works (I think :roll:) if you switch from OpenJDK 11 back to Oracle's JDK 1.8. And even then, I found out that I cannot access marketplace (was it called marketplace or was it delivered in that version of Eclipse at all?) nor update/upgrade/install anything...
clicky
Fri Jul 12, 2019 4:30 pm
OK. Last night (I stayed late as it was so interesting) I had a breakthrough. I'm through the breeze blocks wall now - just to find steel reinforced concrete behind it! :roll:
Anyway - issues I had was because Java was passing 32bit (int!) method signatures to JNI layer and it couldn't find methods as they all had 'longs' (passing "(II)I" for signature while particular method was in reality "(JJ)J"). All in SWT.
I've fixed it in Java (6000+ lines class called Display plus a few minor bits) just for it to crash while JDK because of pointers (32bit pointers) passed around in (GDK class) in such ways it break things (my current theory). Maybe I am not thinking regarding it in the right way. Maybe I should look at 'fixing' it from perspective of JNI (c) code and keep Java code intact. That might be next attempt.
Launcher working (see previous posts with screen shot) gave me some moral boost... we'll see... It would be really great finding anyone involved in Eclipse project to at least say 'hi' in this or their forums or anyone else who is good with such kind of code tinkering... :)
Musketeer
Fri Jul 12, 2019 5:05 pm
... or yet better - port their Open J9 for ARM! :idea:
Linux is like woman - both wants 180 % of your time...
My girlfriend is terribly unmature - she always sinks my boats in bathtub!
Return to “Java”
