apple pi
Using my raspberrypi as a youtrack server
Mon Jan 15, 2018 8:43 pm
Hello
I'm going to purchase my first raspberry pi tomorrow and i want to use it to setup my own youtrack server.
I've read that for webservers or NAS you need to use an external drive, however i would prefer to use a simple SD card instead.
So my question is, will an SD card suffice if i want to use the raspberry pi as my personal youtrack server? There will only be one user.
Thank you!
bertlea
Re: Using my raspberrypi as a youtrack server
Wed Jan 17, 2018 3:34 pm
As long as the SD card got sufficient free space to support your usage,it should be fine. I guess 32G or above should be ok.
Return to “Java”
