Autostart telnetd/sshd?
Posted: Mon Jun 15, 2015 4:21 am
by Tyggerjai
Hi. I've had no problems installing and booting the 9pi image for rpi2, it's great! I'd like to telnet or ssh into the pi, though, from a linux machine. The plan9 documentation for sshd requires editing /etc/ssh/sshd_config, but I have no /etc folder, and trying to create one results in permission problems (cannot create folder on mounted disk?)
I have the telnetd binary, but running it doesn't quite do what I expect - if I try
ip/telnetd -t -u glenda
which is what I expect to result in a telnetd accepting any connection and "logging in" as glenda, then that results in a *local* login saying "cpu%" on the rpi.
Any ideas? All the documentation I've found suggests one of the two above approaches.
Ultimately, I'm hoping to set up a plan9 cluster on a few pis - I gather the networking between them is more straightforward, but it would be nice to connect to the master CPU node from outside.
Thanks in advance!
