Tyggerjai
Autostart telnetd/sshd?
Mon Jun 15, 2015 4:21 am
Hi. I've had no problems installing and booting the 9pi image for rpi2, it's great! I'd like to telnet or ssh into the pi, though, from a linux machine. The plan9 documentation for sshd requires editing /etc/ssh/sshd_config, but I have no /etc folder, and trying to create one results in permission problems (cannot create folder on mounted disk?)
I have the telnetd binary, but running it doesn't quite do what I expect - if I try
ip/telnetd -t -u glenda
which is what I expect to result in a telnetd accepting any connection and "logging in" as glenda, then that results in a *local* login saying "cpu%" on the rpi.
Any ideas? All the documentation I've found suggests one of the two above approaches.
Ultimately, I'm hoping to set up a plan9 cluster on a few pis - I gather the networking between them is more straightforward, but it would be nice to connect to the master CPU node from outside.
Thanks in advance!
Return to “Plan 9”
Who is online
Users browsing this forum: No registered users and 3 guests
