Scrivere un demone in C
Posted: Sat Jan 18, 2014 8:14 pm
by guitar
Ciao a tutti, ho scritto questo codice per la creazione di un demone in linguaggio C. Questo programma non ha alcuna funzione se non la creazione del demone. Potete liberamente implementare programmi che devono girare in background facendo uso di questo codice.
// Daemon Demo
// Demo code for daemon programs
// Author: guitat
// Date: 18/01/2014
// File name: daemondemo.c
// Features:
// 1) start, stop and status function
// 2) pid file management
// 3) system log implemented
#include <stdio.h>
#include <stdarg.h>
#include <string.h>
#include <stdlib.h>
#include <libconfig.h>
#include <unistd.h>
#include <signal.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <syslog.h>
// change these value as well
const char *filepid="/run/daemondemo.pid";
const char *logname="daemondemo";
void signal_callback_handler(int signum){
	pid_t cpid;
	FILE *cfpid;
	if( access( filepid, F_OK ) != -1 ){
		cfpid=fopen(filepid,"r");
		fscanf(cfpid, "%d\n", &cpid);
		fclose(cfpid);
		if (cpid==getpid()){
			closelog();
			remove(filepid);
			abort();
static void daemonize(){
	pid_t dpid;
	FILE *dfpid;
	/* Fork off the parent process */
	dpid = fork();
	/* An error occurred */
	if (dpid < 0)
		exit(EXIT_FAILURE);
	/* Success: Let the parent terminate */
	if (dpid > 0)
		exit(EXIT_SUCCESS);
	/* On success: The child process becomes session leader */
	if (setsid() < 0)
		exit(EXIT_FAILURE);
	/* Catch, ignore and handle signals */
	//TODO: Implement a working signal handler */
	//signal(SIGCHLD, SIG_IGN);
	//signal(SIGHUP, SIG_IGN);
	/* Fork off for the second time*/
	dpid = fork();
	if (dpid < 0)
		exit(EXIT_FAILURE);
	if (dpid > 0)
		exit(EXIT_SUCCESS);
	/* Set new file permissions */
	umask(0);
	/* Change the working directory to the root directory */
	/* or another appropriated directory */
	chdir("/");
	/* Close all open file descriptors */
	int x;
	for (x = sysconf(_SC_OPEN_MAX); x>0; x--)
		close (x);
	// Saving pid in the .pid file
	dfpid=fopen(filepid,"w");
	fprintf(dfpid, "%d\n", getpid());
	fclose(dfpid);
	/* Open the log file */
	openlog (logname, LOG_PID, LOG_DAEMON);
	signal(SIGINT, signal_callback_handler);
	signal(SIGHUP, signal_callback_handler);
	signal(SIGTERM, signal_callback_handler);
	signal(SIGQUIT, signal_callback_handler);
int main (int argc, char **argv)
	FILE *fpid;
	pid_t pid=0;
	if ( argc != 2 ){
		printf ("Usage: %s [start|stop|status]\n", argv[0]);
		return 1;
	}else{
		if (!strcmp(argv[1],"start")){
			if( access( filepid, F_OK ) != -1 ) {
				// pid file exist: daemon is running
				printf("Daemon is already running.\n");
			} else {
				// pid file doesn't exist: daemon is stopped
				daemonize();
				/* INFINITE LOOP WRITE THE BODY OF PROGRAM INSIDE */
				for(;;){
					//body of program
		if (!strcmp(argv[1],"stop")){
				printf("Stopping daemon...");
				fscanf(fpid, "%d\n", &pid);
				fclose(fpid);
				syslog (LOG_NOTICE, "stopping daemon");
				closelog();
				kill(pid, SIGINT);
				printf(" stopped!\n");
			} else {
				printf("Daemon is not running.\n");
		if (!strcmp(argv[1],"status")){
				fclose(fpid);
				printf("Daemon is running with pid: %d.\n",pid);
			} else {
				printf("Daemon is stopped.\n");
	return(EXIT_SUCCESS);
il comando per la compilazione รจ:
gcc -Wall daemondemo.c -o daemondemo
Questo codice gira tranquillamente sia su x86 che su ARM.
