Problema con l istallazione di PiVpn
Posted: Sun Sep 22, 2019 2:24 pm
by Dhy1
Salve,
Sto provando ad installare PiVpn .. ma ad un certo punto l installazione si blocca .. quando vado a scegliere il numero di bit per la criptografia .. mi viene restituito questo a console
root@raspberrypi:/etc# sudo curl --insecure -L https://install.pivpn.io | bash
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 178 100 178 0 0 227 0 --:--:-- --:--:-- --:--:-- 227
100 58458 100 58458 0 0 47837 0 0:00:01 0:00:01 --:--:-- 2049k
::: You are root.
::: Verifying free disk space...
::: Checking apt-get for upgraded packages.... done!
::: Your system is up to date! Continuing with PiVPN installation...
::: Static IP already configured.
::: Using User: pi
::: Checking for existing base files...
::: Checking /etc/.pivpn is a repo...::: Cloning https://github.com/pivpn/pivpn.git into /etc/.pivpn... [/] fatal: unable to access 'https://github.com/pivpn/pivpn.git/': server certificate verification failed. CAfile: none CRLfile: none done!
::: Stopping OpenVPN service... done.
gzip: stdin: unexpected end of file
tar: Child returned status 1
tar: Error is not recoverable: exiting now
cp: cannot stat 'unattended-upgrades-1.9/data/50unattended-upgrades.Raspbian': No such file or directory
::: Installing scripts to /opt/pivpn...cp: cannot stat '/etc/.pivpn/scripts/makeOVPN.sh': No such file or directory
cp: cannot stat '/etc/.pivpn/scripts/clientStat.sh': No such file or directory
cp: cannot stat '/etc/.pivpn/scripts/listOVPN.sh': No such file or directory
cp: cannot stat '/etc/.pivpn/scripts/removeOVPN.sh': No such file or directory
cp: cannot stat '/etc/.pivpn/scripts/uninstall.sh': No such file or directory
cp: cannot stat '/etc/.pivpn/scripts/pivpnDebug.sh': No such file or directory
chmod: cannot access '/opt/pivpn/makeOVPN.sh': No such file or directory
chmod: cannot access '/opt/pivpn/clientStat.sh': No such file or directory
chmod: cannot access '/opt/pivpn/listOVPN.sh': No such file or directory
chmod: cannot access '/opt/pivpn/removeOVPN.sh': No such file or directory
chmod: cannot access '/opt/pivpn/uninstall.sh': No such file or directory
chmod: cannot access '/opt/pivpn/pivpnDebug.sh': No such file or directory
cp: cannot stat '/etc/.pivpn/pivpn': No such file or directory
chmod: cannot access '/usr/local/bin/pivpn': No such file or directory
cp: cannot stat '/etc/.pivpn/scripts/bash-completion': No such file or directory
main: line 414: /etc/bash_completion.d/pivpn: No such file or directory
done.
::: Using protocol: udp
chown: cannot access '/etc/openvpn/easy-rsa': No such file or directory
mkdir: cannot create directory ‘/etc/openvpn/easy-rsa/pki’: No such file or directory
main: line 825: cd: /etc/openvpn/easy-rsa: No such file or directory
Re: Problema con l istallazione di PiVpn
Posted: Sun Sep 22, 2019 3:28 pm
by canislupus80
Il tuo problema principale riguarda il fatto che non riesce a prelevare i file da git a causa del certificato di sicurezza (mancante o non valido).
Innanzitutto verifica se siano presenti i certificati in questo percorso:
/etc/ssl/certs
Facci sapere
Posted: Mon Sep 23, 2019 1:28 pm
by nicolap8
Se un certificato che sembra valido non viene riconosciuto bisogna subito controllare se la data e l'ora del sistema sono aggiornate.
