saifer
Errore Samba: Unit samba.service is masked. Failed to start Samba SMB Daemon
Thu May 16, 2019 9:16 pm
Ciao a tutti, all'improvviso samba ha deciso di non funzionare più. Ho un Pi 3 B+ con raspbian. Samba lo uso per accedere ad un HDD collegato con USB.
sudo service samba start
Failed to start samba.service: Unit samba.service is masked.
Il problema essere il demone smbd
sudo systemctl status smbd.service
● smbd.service - Samba SMB Daemon
   Loaded: loaded (/lib/systemd/system/smbd.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Thu 2019-05-16 22:59:41 CEST; 13min ago
     Docs: man:smbd(8)
           man:samba(7)
           man:smb.conf(5)
  Process: 1828 ExecStart=/usr/sbin/smbd $SMBDOPTIONS (code=exited, status=1/FAILURE)
 Main PID: 1828 (code=exited, status=1/FAILURE)
May 16 22:59:41 raspberrypi systemd[1]: Starting Samba SMB Daemon...
May 16 22:59:41 raspberrypi systemd[1]: smbd.service: Main process exited, code=exited, status=1/FAILURE
May 16 22:59:41 raspberrypi systemd[1]: Failed to start Samba SMB Daemon.
May 16 22:59:41 raspberrypi systemd[1]: smbd.service: Unit entered failed state.
May 16 22:59:41 raspberrypi systemd[1]: smbd.service: Failed with result 'exit-code'.
May 16 23:12:43 raspberrypi systemd[1]: smbd.service: Unit cannot be reloaded because it is inactive.
Ho provato a cancellare e reinstallare samba per intero ma niente. Leggendo online pare essere un bug che samba si porta dietro da un po', ma non sono riuscito a trovare una soluzione. Qualcuno può aiutarmi?
tigernero
Re: Errore Samba: Unit samba.service is masked. Failed to start Samba SMB Daemon
Fri May 17, 2019 8:14 am
prova:
sudo systemctl unmask samba
sudo systemctl enable samba
sudo systemctl restart samba
se non va credo a difetto di microsd
saifer
Fri May 17, 2019 2:14 pm
prova:
Grazie per la risposta, ho provato ma nulla
Synchronizing state of samba.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable samba
update-rc.d: error: samba Default-Start contains no runlevels, aborting.
Failed to restart samba.service: Unit samba.service is masked.
Mi è successa la stessa cosa in passato un paio di volte, l'ultima si "risolse" da sola quasi... la volta prima feci invece diverse cose che alla fine qualcosa risolse il problema (incluso questo), ma che purtroppo non ricordo bene.
Return to “Italiano”
