morris1974
dubbi sul ultimo aggiornamento
Tue May 03, 2016 6:50 pm
Ciao a tutti ieri ho fatto un update con gli aggiornamenti del raspberry via terminale
ho visto questa mole di dati ma non li ho capiti bene visto che non mi era mai capitato neanche sugli altri pc di casa dove ho installato ubuntu
Do you want to continue [Y/n]? y
Get:1 http://archive.raspberrypi.org/debian/ wheezy/main libraspberrypi-dev armhf 1.20160315-1 [403 kB]
Get:2 http://archive.raspberrypi.org/debian/ wheezy/main libraspberrypi-doc armhf 1.20160315-1 [31.4 MB]
Get:3 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libgd2-xpm armhf 2.0.36~rc1~dfsg-6.1+deb7u2 [221 kB]
Get:4 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libpoppler19 armhf 0.18.4-6+deb7u1 [995 kB]
Get:5 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libpoppler-glib8 armhf 0.18.4-6+deb7u1 [90.0 kB]
Get:6 http://mirrordirector.raspbian.org/raspbian/ wheezy/main libimlib2 armhf 1.4.5-1+deb7u2 [234 kB]
Get:7 http://mirrordirector.raspbian.org/raspbian/ wheezy/main poppler-utils armhf 0.18.4-6+deb7u1 [138 kB]
Get:8 http://archive.raspberrypi.org/debian/ wheezy/main libraspberrypi-bin armhf 1.20160315-1 [254 kB]
Get:9 http://archive.raspberrypi.org/debian/ wheezy/main libraspberrypi0 armhf 1.20160315-1 [709 kB]
Get:10 http://archive.raspberrypi.org/debian/ wheezy/main raspberrypi-bootloader armhf 1.20160315-1 [32.1 MB]
Fetched 66.5 MB in 3min 14s (341 kB/s)
(Reading database ... 101756 files and directories currently installed.)
Preparing to replace libgd2-xpm:armhf 2.0.36~rc1~dfsg-6.1+deb7u1 (using .../libgd2-xpm_2.0.36~rc1~dfsg-6.1+deb7u2_armhf.deb) ...
Unpacking replacement libgd2-xpm:armhf ...
Preparing to replace libpoppler19:armhf 0.18.4-6 (using .../libpoppler19_0.18.4-6+deb7u1_armhf.deb) ...
Unpacking replacement libpoppler19:armhf ...
Preparing to replace libpoppler-glib8:armhf 0.18.4-6 (using .../libpoppler-glib8_0.18.4-6+deb7u1_armhf.deb) ...
Unpacking replacement libpoppler-glib8:armhf ...
Preparing to replace libimlib2 1.4.5-1+deb7u1 (using .../libimlib2_1.4.5-1+deb7u2_armhf.deb) ...
Unpacking replacement libimlib2 ...
Preparing to replace poppler-utils 0.18.4-6 (using .../poppler-utils_0.18.4-6+deb7u1_armhf.deb) ...
Unpacking replacement poppler-utils ...
Preparing to replace libraspberrypi-dev 1.20151118-1 (using .../libraspberrypi-dev_1.20160315-1_armhf.deb) ...
Unpacking replacement libraspberrypi-dev ...
Preparing to replace libraspberrypi-doc 1.20151118-1 (using .../libraspberrypi-doc_1.20160315-1_armhf.deb) ...
Unpacking replacement libraspberrypi-doc ...
Preparing to replace libraspberrypi-bin 1.20151118-1 (using .../libraspberrypi-bin_1.20160315-1_armhf.deb) ...
Unpacking replacement libraspberrypi-bin ...
Preparing to replace libraspberrypi0 1.20151118-1 (using .../libraspberrypi0_1.20160315-1_armhf.deb) ...
Unpacking replacement libraspberrypi0 ...
Preparing to replace raspberrypi-bootloader 1.20151118-1 (using .../raspberrypi-bootloader_1.20160315-1_armhf.deb) ...
Adding 'diversion of /boot/COPYING.linux to /usr/share/rpikernelhack/COPYING.linux by rpikernelhack'
Adding 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
Adding 'diversion of /boot/bcm2708-rpi-b-plus.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-plus.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2708-rpi-b.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2708-rpi-cm.dtb to /usr/share/rpikernelhack/bcm2708-rpi-cm.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2709-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2709-rpi-2-b.dtb by rpikernelhack'
Adding 'diversion of /boot/bcm2710-rpi-3-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb by rpikernelhack'
Adding 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
Adding 'diversion of /boot/fixup.dat to /usr/share/rpikernelhack/fixup.dat by rpikernelhack'
Adding 'diversion of /boot/fixup_cd.dat to /usr/share/rpikernelhack/fixup_cd.dat by rpikernelhack'
Adding 'diversion of /boot/fixup_db.dat to /usr/share/rpikernelhack/fixup_db.dat by rpikernelhack'
Adding 'diversion of /boot/fixup_x.dat to /usr/share/rpikernelhack/fixup_x.dat by rpikernelhack'
Adding 'diversion of /boot/kernel.img to /usr/share/rpikernelhack/kernel.img by rpikernelhack'
Adding 'diversion of /boot/kernel7.img to /usr/share/rpikernelhack/kernel7.img by rpikernelhack'
Adding 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
Adding 'diversion of /boot/start_cd.elf to /usr/share/rpikernelhack/start_cd.elf by rpikernelhack'
Adding 'diversion of /boot/start_db.elf to /usr/share/rpikernelhack/start_db.elf by rpikernelhack'
Adding 'diversion of /boot/start_x.elf to /usr/share/rpikernelhack/start_x.elf by rpikernelhack'
Adding 'diversion of /boot/overlays/README to /usr/share/rpikernelhack/overlays/README by rpikernelhack'
Adding 'diversion of /boot/overlays/ads7846-overlay.dtb to /usr/share/rpikernelhack/overlays/ads7846-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/at86rf233-overlay.dtb to /usr/share/rpikernelhack/overlays/at86rf233-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/bmp085_i2c-sensor-overlay.dtb to /usr/share/rpikernelhack/overlays/bmp085_i2c-sensor-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/dht11-overlay.dtb to /usr/share/rpikernelhack/overlays/dht11-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/enc28j60-overlay.dtb to /usr/share/rpikernelhack/overlays/enc28j60-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-ir-overlay.dtb to /usr/share/rpikernelhack/overlays/gpio-ir-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/gpio-poweroff-overlay.dtb to /usr/share/rpikernelhack/overlays/gpio-poweroff-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-amp-overlay.dtb to /usr/share/rpikernelhack/overlays/hifiberry-amp-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-dac-overlay.dtb to /usr/share/rpikernelhack/overlays/hifiberry-dac-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-dacplus-overlay.dtb to /usr/share/rpikernelhack/overlays/hifiberry-dacplus-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/hifiberry-digi-overlay.dtb to /usr/share/rpikernelhack/overlays/hifiberry-digi-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/hy28a-overlay.dtb to /usr/share/rpikernelhack/overlays/hy28a-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/hy28b-overlay.dtb to /usr/share/rpikernelhack/overlays/hy28b-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-gpio-overlay.dtb to /usr/share/rpikernelhack/overlays/i2c-gpio-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c-rtc-overlay.dtb to /usr/share/rpikernelhack/overlays/i2c-rtc-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c0-bcm2708-overlay.dtb to /usr/share/rpikernelhack/overlays/i2c0-bcm2708-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/i2c1-bcm2708-overlay.dtb to /usr/share/rpikernelhack/overlays/i2c1-bcm2708-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/i2s-mmap-overlay.dtb to /usr/share/rpikernelhack/overlays/i2s-mmap-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/iqaudio-dac-overlay.dtb to /usr/share/rpikernelhack/overlays/iqaudio-dac-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/iqaudio-dacplus-overlay.dtb to /usr/share/rpikernelhack/overlays/iqaudio-dacplus-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/lirc-rpi-overlay.dtb to /usr/share/rpikernelhack/overlays/lirc-rpi-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp2515-can0-overlay.dtb to /usr/share/rpikernelhack/overlays/mcp2515-can0-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/mcp2515-can1-overlay.dtb to /usr/share/rpikernelhack/overlays/mcp2515-can1-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/mmc-overlay.dtb to /usr/share/rpikernelhack/overlays/mmc-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/mz61581-overlay.dtb to /usr/share/rpikernelhack/overlays/mz61581-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/pi3-disable-bt-overlay.dtb to /usr/share/rpikernelhack/overlays/pi3-disable-bt-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/pi3-miniuart-bt-overlay.dtb to /usr/share/rpikernelhack/overlays/pi3-miniuart-bt-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/piscreen-overlay.dtb to /usr/share/rpikernelhack/overlays/piscreen-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/piscreen2r-overlay.dtb to /usr/share/rpikernelhack/overlays/piscreen2r-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/pitft28-capacitive-overlay.dtb to /usr/share/rpikernelhack/overlays/pitft28-capacitive-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/pitft28-resistive-overlay.dtb to /usr/share/rpikernelhack/overlays/pitft28-resistive-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/pps-gpio-overlay.dtb to /usr/share/rpikernelhack/overlays/pps-gpio-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/pwm-2chan-overlay.dtb to /usr/share/rpikernelhack/overlays/pwm-2chan-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/pwm-overlay.dtb to /usr/share/rpikernelhack/overlays/pwm-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/qca7000-overlay.dtb to /usr/share/rpikernelhack/overlays/qca7000-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/raspidac3-overlay.dtb to /usr/share/rpikernelhack/overlays/raspidac3-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-backlight-overlay.dtb to /usr/share/rpikernelhack/overlays/rpi-backlight-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-dac-overlay.dtb to /usr/share/rpikernelhack/overlays/rpi-dac-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-display-overlay.dtb to /usr/share/rpikernelhack/overlays/rpi-display-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-ft5406-overlay.dtb to /usr/share/rpikernelhack/overlays/rpi-ft5406-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-proto-overlay.dtb to /usr/share/rpikernelhack/overlays/rpi-proto-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/rpi-sense-overlay.dtb to /usr/share/rpikernelhack/overlays/rpi-sense-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/sdhost-overlay.dtb to /usr/share/rpikernelhack/overlays/sdhost-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/sdio-overlay.dtb to /usr/share/rpikernelhack/overlays/sdio-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/smi-dev-overlay.dtb to /usr/share/rpikernelhack/overlays/smi-dev-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/smi-nand-overlay.dtb to /usr/share/rpikernelhack/overlays/smi-nand-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/smi-overlay.dtb to /usr/share/rpikernelhack/overlays/smi-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/spi-bcm2708-overlay.dtb to /usr/share/rpikernelhack/overlays/spi-bcm2708-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/spi-bcm2835-overlay.dtb to /usr/share/rpikernelhack/overlays/spi-bcm2835-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/spi-dma-overlay.dtb to /usr/share/rpikernelhack/overlays/spi-dma-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/tinylcd35-overlay.dtb to /usr/share/rpikernelhack/overlays/tinylcd35-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/uart1-overlay.dtb to /usr/share/rpikernelhack/overlays/uart1-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/vc4-kms-v3d-overlay.dtb to /usr/share/rpikernelhack/overlays/vc4-kms-v3d-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/vga666-overlay.dtb to /usr/share/rpikernelhack/overlays/vga666-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/w1-gpio-overlay.dtb to /usr/share/rpikernelhack/overlays/w1-gpio-overlay.dtb by rpikernelhack'
Adding 'diversion of /boot/overlays/w1-gpio-pullup-overlay.dtb to /usr/share/rpikernelhack/overlays/w1-gpio-pullup-overlay.dtb by rpikernelhack'
Unpacking replacement raspberrypi-bootloader ...
Processing triggers for man-db ...
Setting up libgd2-xpm:armhf (2.0.36~rc1~dfsg-6.1+deb7u2) ...
Setting up libpoppler19:armhf (0.18.4-6+deb7u1) ...
Setting up libpoppler-glib8:armhf (0.18.4-6+deb7u1) ...
Setting up libimlib2 (1.4.5-1+deb7u2) ...
Setting up poppler-utils (0.18.4-6+deb7u1) ...
Setting up raspberrypi-bootloader (1.20160315-1) ...
Removing 'diversion of /boot/COPYING.linux to /usr/share/rpikernelhack/COPYING.linux by rpikernelhack'
Removing 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
Removing 'diversion of /boot/bcm2708-rpi-b-plus.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-plus.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2708-rpi-b.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2708-rpi-cm.dtb to /usr/share/rpikernelhack/bcm2708-rpi-cm.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2709-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2709-rpi-2-b.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2710-rpi-3-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb by rpikernelhack'
Removing 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
Removing 'diversion of /boot/fixup.dat to /usr/share/rpikernelhack/fixup.dat by rpikernelhack'
Removing 'diversion of /boot/fixup_cd.dat to /usr/share/rpikernelhack/fixup_cd.dat by rpikernelhack'
Removing 'diversion of /boot/fixup_db.dat to /usr/share/rpikernelhack/fixup_db.dat by rpikernelhack'
Removing 'diversion of /boot/fixup_x.dat to /usr/share/rpikernelhack/fixup_x.dat by rpikernelhack'
Removing 'diversion of /boot/kernel.img to /usr/share/rpikernelhack/kernel.img by rpikernelhack'
Removing 'diversion of /boot/kernel7.img to /usr/share/rpikernelhack/kernel7.img by rpikernelhack'
Removing 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
Removing 'diversion of /boot/start_cd.elf to /usr/share/rpikernelhack/start_cd.elf by rpikernelhack'
Removing 'diversion of /boot/start_db.elf to /usr/share/rpikernelhack/start_db.elf by rpikernelhack'
Removing 'diversion of /boot/start_x.elf to /usr/share/rpikernelhack/start_x.elf by rpikernelhack'
Removing 'diversion of /boot/overlays/README to /usr/share/rpikernelhack/overlays/README by rpikernelhack'
Removing 'diversion of /boot/overlays/ads7846-overlay.dtb to /usr/share/rpikernelhack/overlays/ads7846-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/at86rf233-overlay.dtb to /usr/share/rpikernelhack/overlays/at86rf233-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/bmp085_i2c-sensor-overlay.dtb to /usr/share/rpikernelhack/overlays/bmp085_i2c-sensor-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/dht11-overlay.dtb to /usr/share/rpikernelhack/overlays/dht11-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/enc28j60-overlay.dtb to /usr/share/rpikernelhack/overlays/enc28j60-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-ir-overlay.dtb to /usr/share/rpikernelhack/overlays/gpio-ir-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-poweroff-overlay.dtb to /usr/share/rpikernelhack/overlays/gpio-poweroff-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-amp-overlay.dtb to /usr/share/rpikernelhack/overlays/hifiberry-amp-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-dac-overlay.dtb to /usr/share/rpikernelhack/overlays/hifiberry-dac-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-dacplus-overlay.dtb to /usr/share/rpikernelhack/overlays/hifiberry-dacplus-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-digi-overlay.dtb to /usr/share/rpikernelhack/overlays/hifiberry-digi-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/hy28a-overlay.dtb to /usr/share/rpikernelhack/overlays/hy28a-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/hy28b-overlay.dtb to /usr/share/rpikernelhack/overlays/hy28b-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-gpio-overlay.dtb to /usr/share/rpikernelhack/overlays/i2c-gpio-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-rtc-overlay.dtb to /usr/share/rpikernelhack/overlays/i2c-rtc-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c0-bcm2708-overlay.dtb to /usr/share/rpikernelhack/overlays/i2c0-bcm2708-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c1-bcm2708-overlay.dtb to /usr/share/rpikernelhack/overlays/i2c1-bcm2708-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/i2s-mmap-overlay.dtb to /usr/share/rpikernelhack/overlays/i2s-mmap-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/iqaudio-dac-overlay.dtb to /usr/share/rpikernelhack/overlays/iqaudio-dac-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/iqaudio-dacplus-overlay.dtb to /usr/share/rpikernelhack/overlays/iqaudio-dacplus-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/lirc-rpi-overlay.dtb to /usr/share/rpikernelhack/overlays/lirc-rpi-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp2515-can0-overlay.dtb to /usr/share/rpikernelhack/overlays/mcp2515-can0-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp2515-can1-overlay.dtb to /usr/share/rpikernelhack/overlays/mcp2515-can1-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/mmc-overlay.dtb to /usr/share/rpikernelhack/overlays/mmc-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/mz61581-overlay.dtb to /usr/share/rpikernelhack/overlays/mz61581-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/pi3-disable-bt-overlay.dtb to /usr/share/rpikernelhack/overlays/pi3-disable-bt-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/pi3-miniuart-bt-overlay.dtb to /usr/share/rpikernelhack/overlays/pi3-miniuart-bt-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/piscreen-overlay.dtb to /usr/share/rpikernelhack/overlays/piscreen-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/piscreen2r-overlay.dtb to /usr/share/rpikernelhack/overlays/piscreen2r-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/pitft28-capacitive-overlay.dtb to /usr/share/rpikernelhack/overlays/pitft28-capacitive-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/pitft28-resistive-overlay.dtb to /usr/share/rpikernelhack/overlays/pitft28-resistive-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/pps-gpio-overlay.dtb to /usr/share/rpikernelhack/overlays/pps-gpio-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/pwm-2chan-overlay.dtb to /usr/share/rpikernelhack/overlays/pwm-2chan-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/pwm-overlay.dtb to /usr/share/rpikernelhack/overlays/pwm-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/qca7000-overlay.dtb to /usr/share/rpikernelhack/overlays/qca7000-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/raspidac3-overlay.dtb to /usr/share/rpikernelhack/overlays/raspidac3-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-backlight-overlay.dtb to /usr/share/rpikernelhack/overlays/rpi-backlight-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-dac-overlay.dtb to /usr/share/rpikernelhack/overlays/rpi-dac-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-display-overlay.dtb to /usr/share/rpikernelhack/overlays/rpi-display-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-ft5406-overlay.dtb to /usr/share/rpikernelhack/overlays/rpi-ft5406-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-proto-overlay.dtb to /usr/share/rpikernelhack/overlays/rpi-proto-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-sense-overlay.dtb to /usr/share/rpikernelhack/overlays/rpi-sense-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/sdhost-overlay.dtb to /usr/share/rpikernelhack/overlays/sdhost-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/sdio-overlay.dtb to /usr/share/rpikernelhack/overlays/sdio-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/smi-dev-overlay.dtb to /usr/share/rpikernelhack/overlays/smi-dev-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/smi-nand-overlay.dtb to /usr/share/rpikernelhack/overlays/smi-nand-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/smi-overlay.dtb to /usr/share/rpikernelhack/overlays/smi-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/spi-bcm2708-overlay.dtb to /usr/share/rpikernelhack/overlays/spi-bcm2708-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/spi-bcm2835-overlay.dtb to /usr/share/rpikernelhack/overlays/spi-bcm2835-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/spi-dma-overlay.dtb to /usr/share/rpikernelhack/overlays/spi-dma-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/tinylcd35-overlay.dtb to /usr/share/rpikernelhack/overlays/tinylcd35-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/uart1-overlay.dtb to /usr/share/rpikernelhack/overlays/uart1-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-v3d-overlay.dtb to /usr/share/rpikernelhack/overlays/vc4-kms-v3d-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/vga666-overlay.dtb to /usr/share/rpikernelhack/overlays/vga666-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/w1-gpio-overlay.dtb to /usr/share/rpikernelhack/overlays/w1-gpio-overlay.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/w1-gpio-pullup-overlay.dtb to /usr/share/rpikernelhack/overlays/w1-gpio-pullup-overlay.dtb by rpikernelhack'
Setting up libraspberrypi0 (1.20160315-1) ...
Setting up libraspberrypi-dev (1.20160315-1) ...
Setting up libraspberrypi-doc (1.20160315-1) ...
Setting up libraspberrypi-bin (1.20160315-1) .
quello che non capisco è se per caso la mia raspberry ha dei problemi di sicurezza perché mi sono preoccupato quando ho visto che mi dice quel rpikernelhack che non so cosa sia, la raspberry funziona ma per sicurezza mia ho spento tutto, ho cercato su google ma non ho trovato nulla quindi mi domandavo se dovessi reinstallare tutto ex novo oppure posso stare tranquillo, spero che qualche utente possa darmi delle spiegazioni in merito sulla cosa.
Intanto ringrazio tutti per l'aiuto che mi darete :)
Return to “Italiano”
