icsafer wrote:grazie ora riprovo
Ciao a tutti...
sto provando anche io ad installare ma ottengo il seguente errore... qualcuno sa aiutarmi???
osmc@JWH:~$ sudo apt-get install transmission-daemon
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
transmission-common
The following NEW packages will be installed:
transmission-common transmission-daemon
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 438 kB of archives.
After this operation, 1314 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://ftp.debian.org/debian/ jessie/main transmission-common all 2.84-0.2 [257 kB]
Get:2 http://ftp.debian.org/debian/ jessie/main transmission-daemon armhf 2.84-0.2 [181 kB]
Fetched 438 kB in 1s (368 kB/s)
(Reading database ... 27358 files and directories currently installed.)
Preparing to unpack .../transmission-common_2.84-0.2_all.deb ...
Unpacking transmission-common (2.84-0.2) ...
dpkg: error processing archive /var/cache/apt/archives/transmission-common_2.84-0.2_all.deb (--unpack):
trying to overwrite '/usr/share/transmission/web/index.html', which is also in package armv7-transmission-app-osmc 2.8.4-11
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Preparing to unpack .../transmission-daemon_2.84-0.2_armhf.deb ...
Unpacking transmission-daemon (2.84-0.2) ...
dpkg: error processing archive /var/cache/apt/archives/transmission-daemon_2.84-0.2_armhf.deb (--unpack):
trying to overwrite '/usr/bin/transmission-daemon', which is also in package armv7-transmission-app-osmc 2.8.4-11
Processing triggers for hicolor-icon-theme (0.13-1) ...
