I can get FBA to acknowledge it supports the CPS3 roms, and include the CPS3 roms in it's gamelist output, but as soon as it starts to load a CPS 3 rom it throws a generic memory error and exits. Has anyone else had any luck enabling the CPS 3 drivers?
I'm not sure if the CPS3 modules in the PiFBA source code even work, so I can't tell if I'm just not linking them properly or if they just don't work
Update: With a little bit more of a play I was able to get sfiiin.zip to play, though I'm still without audio.
I compiled with these options and got a mostly solid 60fps with only the occasional dip to the mid 50's (within XWindows!), so it certainly has the power for fluid CPS 3 emulation at stock speeds.Found 1 joysticks
Attempt to initialise 'Street Fighter III: New Generation (Asia 970204, NO CD)'
Screen Size: 384 x 224
sfiii_asia_nocd.29f400.u2 ... 512Kb BIOS (OK)
10 ... 8192Kb program (OK)
30 ... 8192Kb graphics (OK)
31 ... 8192Kb graphics (OK)
40 ... 8192Kb graphics (OK)
41 ... 8192Kb graphics (OK)
50 ... 4096Kb graphics (OK)
Lets go!
ALSA: Period size: 736 frames
ALSA: Buffer size: 2940 frames
ALSA: Period size: 2944 bytes
ALSA: Buffer size: 11760 bytes
Finished emulating
---- Shutdown Finalburn Alpha plus ----
ALSA: FIFO Underrun: 618
ALSA: FIFO Overrun: 0
ALSA: Snd Underrun 0
-mcpu=cortex-a7 -mfpu=neon-vfpv4 -mfloat-abi=hard
