alb85
Play with Hexen,Heretic on Raspberry
Thu Jan 15, 2015 3:07 pm
Hello everybody,
I've seen that it is possible to play Doom using prboom (it is already installe on the SD card image provided by Retropie project http://blog.petrockblock.com/download/r ... ect-image/).
Unfortunately, as mentioned in the post http://www.raspberrypi.org/forums/viewtopic.php?t=21923 if you want to play with similar games like Heretic or Hexen you need "raven branch" of chocolate doom (http://www.chocolate-doom.org/wiki/inde ... ven-branch).
I'm not an expert of programming in Linux etc, so is there someone out there that is able to run these games on raspberry???
P.S:
1) Dos emulators are not the best solution due to performances issues.
2) I've already have the hexen.wad and heretic.wad but is not enough :)
Many thanks!!!
Vanfanel
Re: Play with Hexen,Heretic on Raspberry
Fri Jan 16, 2015 10:32 am
Just to save you some work, from the page you linked:
Current status
raven-branch is now obsolete. Version 2.0 of Chocolate Doom integrated the changes made on raven-branch and now includes support for Heretic and Hexen.
So forget about the "Raven branch".
ulysess
Fri Jan 16, 2015 11:03 am
Casually I played Heretic on the Pi a few weeks ago.
I made a script to install crispy doom here. You must to pass the .wad file like a parameter.
Example: crispy-doom -wad /home/pi/heretic.wad
Enjoy! :D
  • PiKISS for Raspberry Pi: https://github.com/jmcerrejon/PiKISS
  • Blog: https://misapuntesde.com/
  • Patreon: https://www.patreon.com/cerrejon?fan_landing=true
  • Twitter: https://twitter.com/ulysess10
  • Discord: https://discord.gg/Y7WFeC5
alb85
Fri Jan 16, 2015 11:25 am
Great!
Many Thanks!
What about the performances?
Tomorrow I'll try the script.
In your website I see also scripts for quake and wolfenstein ... what about those?? :P :P :P
ulysess
Fri Jan 16, 2015 3:48 pm
alb85 wrote:Great!
Many Thanks!
The games runs flawlessly (even quake). Maybe you need to search the .wad files (the script try to download, but maybe the link is broken).
alb85
Sun Jan 18, 2015 5:19 pm
I tested the games:
The first time I execute the command "crispy-doom -wad /home/pi/heretic.wad" it works, but the second time only the sound starts and a black screen appear. If I press the buttons I heard the sounds of the menu etc...
Any idea??
Thanks!
ulysess
Mon Jan 19, 2015 1:16 pm
alb85 wrote:I tested the games:
Any idea??
Thanks!
Seems a problem with your display. Did you use hdmi, rgb? Try another TV or erase the config file.
alb85
Mon Jan 19, 2015 1:55 pm
I testet it with both HDMI and RGB.
I don't undestand why the first time it works....
another question:
I have also other .wad files like:
- Final Doom — The Plutonia Experiment
- Final Doom — TNT: Evilution
- Hexen: Deathkings of the Dark Citadel
Is it possible to play also with those??
ulysess
Wed Jan 21, 2015 1:07 pm
alb85 wrote: another question:
Just try with the same method.
alb85
Fri Jan 23, 2015 9:43 am
I tested the wad files of :
and they don't work.
I still have the problem with doom,hexen and heretic... when I turn on my raspberry and try the game the first time it works.
If I exit the game and enter again only the sound and the controllers work, not the video.. a black screen appear. It seems that when I exit the game the video setting are changed.
This is the console output during the execution of the game:
Crispy Doom 1.3
V_Init: allocate screens.
M_LoadDefaults: Load system defaults.
Using /home/pi/.crispy-doom/ for configuration and saves
saving config in /home/pi/.crispy-doom/hexen.cfg
Z_Init: Init zone memory allocation daemon.
zone memory: 0xb5272008, 1000000 allocated for zone
W_Init: Init WADfiles.
adding /home/pi/RetroPie/roms/ports/hexen/HEXEN.WAD
Hexen
Crispy Doom is free software, covered by the GNU General Public
License. There is NO warranty; not even for MERCHANTABILITY or FITNESS
FOR A PARTICULAR PURPOSE. You are welcome to change and distribute
copies under certain conditions. See the source for more information.
MN_Init: Init menu system.
CT_Init: Init chat mode data.
S_InitScript
SN_InitSequenceScript: Registering sound sequences.
I_Init: Setting up machine state.
I_InitJoystick: Logitech Inc. WingMan RumblePad
OPL_Init: Using driver 'SDL'.
NET_Init: Init networking subsystem.
ST_Init: Init startup screen.
R_Init: Init Hexen refresh daemon..................................
P_Init: Init Playloop state.
D_CheckNetGame: Checking network game status.
SB_Init: Loading patches.
I_InitGraphics: Windowboxed (800x600 within 1024x768)
I_InitSquashTable: Generating lookup tables....
Hexen: Beyond Heretic
I also tried to modify and delete the configs files but the result is the same...
ulysess
Fri Jan 23, 2015 10:25 am
I'll try to test it. What RPi model do you have?, Do you use Raspbian? Version?
alb85
Fri Jan 23, 2015 10:29 am
I have the model B+.
I dont remember the version, this evening I'll check. However I updated everything two days ago...
Return to “Gaming”
