Re: recalboxOS - emulation platform for RPi and RPi2
Posted: Tue Mar 03, 2015 11:03 am
I did not test it with real controllers. Did you ?
A small, affordable computer with free resources to help people learn, make things, and have fun
https://www.raspberrypi.org/forums/
https://www.raspberrypi.org/forums/viewtopic.php?f=78&t=96516
Is it a HDMI projector?terminator2k2 wrote:hi there, im using a different adapter on a small projector now.....the pi boots up and displays in 800 x 600 but the maximum resolution of the projector is 1280 x 720
Stop using that ancient history. The current docs for /boot/config.txt are at: http://www.raspberrypi.org/documentatio ... fig-txt.mdDigitalLumberjack wrote:Check hdmi_mode and hdmi_drive http://elinux.org/RPiconfig#Video_mode_options
still not tested here. now jumped update available and looking that I 2.3.4. so again copy the card: DDigitalLumberjack wrote:I did not test it with real controllers. Did you ?
I will try to test it today!!!DigitalLumberjack wrote:Hello, before the final release of v3.2.5, i would like to have some feedback.
You can download it from http://archive2.recalbox.com/recalboxOS-v3.2.5.zip and test it on your rpi 1 and rpi 2
The news are :
- Refactored the boot system
- added /recalbox/share/system/recalbox.conf for fine tuning (see recalbox.conf on wiki)
- Support db9 and gamecon drivers from recalbox.conf
- Add wifi config from recalbox.conf
- Add language and keyboard selection from recalbox.conf (still keyboard issues in emulationstation)
- Added xboxdrv binary
So if any of you can test for exemaple xboxdrv in command line, the wifi etc, and give us feedback here, i would be glad
In order to edit config.txt file, plug a keyboard and let Shift pressed at startup, then "e" and edit the file from here.terminator2k2 wrote:hi there, im trying to get my monitor up and running which uses dvi.
im using a hdmi to dvi adapter.
eveytime I change the config I get the multi-coloured start screen then the monitor says out of range.
so today Im using a different adapter and a projector with dvi input.
this was my config:
disable_overscan=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=9 (tried different modes)
config_hdmi_boost=4
hdmi_force_hotplug=0 - also tried 1
# uncomment for composite PAL
#sdtv_mode=2
# Overclock
gpu_mem=512
avoid_safe_mode=1
kernel=zImage
ive also tried removing:
hdmi_drive=2
hdmi_safe=1
does it matter that the config.txt is in sd card/os/recalboxOS-rpi2/boot.tar.xe
snoopyk wrote:still not tested here. now jumped update available and looking that I 2.3.4. so again copy the card: DDigitalLumberjack wrote:I did not test it with real controllers. Did you ?
still have questions: how do I get to the config file? I could turn on the DB9.
SSH never used here: D
could you give me the result of `dmesg` when pluggin it ?snoopyk wrote:DigitalLumberjack: Pls Support TP-Link TL-WN722N USB wireless adapter
DigitalLumberjack wrote:could you give me the result of `dmesg` when pluggin it ?snoopyk wrote:DigitalLumberjack: Pls Support TP-Link TL-WN722N USB wireless adapter
# dmesg
[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.18.5-v7 (matthieu@sd-69673) (gcc version 4.9.2 (B uildroot 2015.02-git-gb23875c-dirty) ) #2 SMP PREEMPT Mon Mar 2 21:24:14 CET 201 5
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio n cache
[ 0.000000] Machine: BCM2709
[ 0.000000] cma: Reserved 8 MiB at 0x1e800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 126976
[ 0.000000] free_area_init_node: node 0, pgdat 809f27c0, node_mem_map 9e41300 0
[ 0.000000] Normal zone: 992 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 126976 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (8620->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 11 pages/cpu @9e3e3000 s12736 r8192 d24128 u4505 6
[ 0.000000] pcpu-alloc: s12736 r8192 d24128 u45056 alloc=11*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 125984
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=640 b cm2708_fb.fbheight=480 bcm2709.boardrev=0xa01041 bcm2709.serial=0x884dee7e smsc9 5xx.macaddr=B8:27:EB:4D:EE:7E bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm27 09.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base =0x3dc00000 vc_mem.mem_size=0x3f000000 dwc_otg.fiq_fix_enable=1 sdhci-bcm2708.s ync_after_dma=0 dwc_otg.lpm_enable=0 console=tty3 loglevel=3 elevator=deadline v t.global_cursor_default=0 logo.nologo root=/dev/mmcblk0p6 rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 484124K/507904K available (7279K kernel code, 401K rwdata , 2052K rodata, 464K init, 771K bss, 23780K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
[ 0.000000] vmalloc : 0x9f800000 - 0xff000000 (1528 MB)
[ 0.000000] lowmem : 0x80000000 - 0x9f000000 ( 496 MB)
[ 0.000000] modules : 0x7f000000 - 0x80000000 ( 16 MB)
[ 0.000000] .text : 0x80008000 - 0x80925090 (9333 kB)
[ 0.000000] .init : 0x80926000 - 0x8099a000 ( 464 kB)
[ 0.000000] .data : 0x8099a000 - 0x809fe6d4 ( 402 kB)
[ 0.000000] .bss : 0x809fe6d4 - 0x80abf634 ( 772 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:480
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (virt).
[ 0.000015] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 35791 39424256ns
[ 0.000036] Switching to timer-based delay loop, resolution 52ns
[ 0.000314] Console: colour dummy device 80x30
[ 0.000537] console [tty3] enabled
[ 0.000566] Calibrating delay loop (skipped), value calculated using timer fr equency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000593] pid_max: default: 32768 minimum: 301
[ 0.001039] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001060] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.002295] Initializing cgroup subsys memory
[ 0.002345] Initializing cgroup subsys devices
[ 0.002369] Initializing cgroup subsys freezer
[ 0.002394] Initializing cgroup subsys blkio
[ 0.002500] CPU: Testing write buffer coherency: ok
[ 0.002584] ftrace: allocating 23580 entries in 70 pages
[ 0.060234] missing device node for CPU 0
[ 0.060274] missing device node for CPU 1
[ 0.060285] missing device node for CPU 2
[ 0.060296] missing device node for CPU 3
[ 0.060319] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.060335] [bcm2709_smp_prepare_cpus] enter
[ 0.060490] Setting up static identity map for 0x697718 - 0x697770
[ 0.120243] [bcm2709_boot_secondary] cpu:1 started (0) 17
[ 0.120619] CPU1: Booted secondary processor
[ 0.120628] [bcm2709_secondary_init] enter cpu:1
[ 0.120686] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.140225] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.140536] CPU2: Booted secondary processor
[ 0.140543] [bcm2709_secondary_init] enter cpu:2
[ 0.140576] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.160268] [bcm2709_boot_secondary] cpu:3 started (0) 18
[ 0.160493] CPU3: Booted secondary processor
[ 0.160499] [bcm2709_secondary_init] enter cpu:3
[ 0.160532] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.160628] Brought up 4 CPUs
[ 0.160659] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.160670] CPU: All CPU(s) started in SVC mode.
[ 0.161706] devtmpfs: initialized
[ 0.185499] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.187906] pinctrl core: initialized pinctrl subsystem
[ 0.188394] regulator-dummy: no parameters
[ 0.189102] NET: Registered protocol family 16
[ 0.194930] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.220065] cpuidle: using governor ladder
[ 0.250097] cpuidle: using governor menu
[ 0.250635] bcm2709.uart_clock = 3000000
[ 0.252428] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.252444] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.252481] mailbox: Broadcom VideoCore Mailbox driver
[ 0.252578] bcm2708_vcio: mailbox at f300b880
[ 0.252665] bcm_power: Broadcom power driver
[ 0.252680] bcm_power_open() -> 0
[ 0.252691] bcm_power_request(0, 8)
[ 0.753381] bcm_mailbox_read -> 00000080, 0
[ 0.753394] bcm_power_request -> 0
[ 0.753542] Serial: AMBA PL011 UART driver
[ 0.753672] dev:f1: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 0.823009] SCSI subsystem initialized
[ 0.823446] usbcore: registered new interface driver usbfs
[ 0.823550] usbcore: registered new interface driver hub
[ 0.823694] usbcore: registered new device driver usb
[ 0.824356] Advanced Linux Sound Architecture Driver Initialized.
[ 0.825221] Bluetooth: Core ver 2.19
[ 0.825289] NET: Registered protocol family 31
[ 0.825303] Bluetooth: HCI device and connection manager initialized
[ 0.825328] Bluetooth: HCI socket layer initialized
[ 0.825347] Bluetooth: L2CAP socket layer initialized
[ 0.825395] Bluetooth: SCO socket layer initialized
[ 0.826012] cfg80211: Calling CRDA to update world regulatory domain
[ 0.827131] Switched to clocksource arch_sys_counter
[ 0.867027] FS-Cache: Loaded
[ 0.867424] CacheFiles: Loaded
[ 0.879331] NET: Registered protocol family 2
[ 0.880472] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.880559] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.880663] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.880741] TCP: reno registered
[ 0.880762] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.880802] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.881118] NET: Registered protocol family 1
[ 0.881695] RPC: Registered named UNIX socket transport module.
[ 0.881714] RPC: Registered udp transport module.
[ 0.881724] RPC: Registered tcp transport module.
[ 0.881735] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.882619] bcm2708_dma: DMA manager at f3007000
[ 0.882755] bcm2708_gpio: bcm2708_gpio_probe 809be858
[ 0.883485] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000 000(1008 MiB)
[ 0.885064] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.885305] audit: initializing netlink subsys (disabled)
[ 0.885385] audit: type=2000 audit(0.849:1): initialized
[ 0.903108] DLM installed
[ 0.905963] FS-Cache: Netfs 'nfs' registered for caching
[ 0.906737] NFS: Registering the id_resolver key type
[ 0.906852] Key type id_resolver registered
[ 0.906866] Key type id_legacy registered
[ 0.906969] ntfs: driver 2.1.31 [Flags: R/W].
[ 0.907934] fuse init (API version 7.23)
[ 0.908744] msgmni has been set to 961
[ 0.911445] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 52)
[ 0.911641] io scheduler noop registered
[ 0.911667] io scheduler deadline registered (default)
[ 0.912004] io scheduler cfq registered
[ 0.913766] BCM2708FB: allocated DMA memory dec00000
[ 0.913813] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.921254] Console: switching to colour frame buffer device 80x30
[ 0.926017] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driv er
[ 0.926498] uart-pl011 dev:f1: no DMA platform data
[ 0.926992] vc-cma: Videocore CMA driver
[ 0.927006] vc-cma: vc_cma_base = 0x00000000
[ 0.927017] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.927029] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.938971] brd: module loaded
[ 0.944880] loop: module loaded
[ 0.945231] vchiq: vchiq_init_state: slot_zero = 0x9e800000, is_master = 0
[ 0.946001] Loading iSCSI transport class v2.0-870.
[ 0.946802] usbcore: registered new interface driver cdc_ether
[ 0.946942] usbcore: registered new interface driver smsc95xx
[ 0.947009] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.947031] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.947085] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.147494] Core Release: 2.80a
[ 1.147514] Setting default values for core params
[ 1.147562] Finished setting default values for core params
[ 1.347985] Using Buffer DMA mode
[ 1.348002] Periodic Transfer Interrupt Enhancement - disabled
[ 1.348012] Multiprocessor Interrupt Enhancement - disabled
[ 1.348024] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.348041] Dedicated Tx FIFOs mode
[ 1.348376] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0x9ec 14000 dma = 0xdec14000 len=9024
[ 1.348414] FIQ FSM acceleration enabled for :
[ 1.348414] Non-periodic Split Transactions
[ 1.348414] Periodic Split Transactions
[ 1.348414] High-Speed Isochronous Endpoints
[ 1.348439] dwc_otg: Microframe scheduler enabled
[ 1.348510] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x804364cc
[ 1.348530] WARN::hcd_init_fiq:413: FIQ ASM at 0x8043683c length 36
[ 1.348549] WARN::hcd_init_fiq:438: MPHI regs_base at 0x9f806000
[ 1.348577] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.348626] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.348684] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.348743] Init: Port Power? op_state=1
[ 1.348754] Init: Power Port (0)
[ 1.349050] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.349070] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber= 1
[ 1.349086] usb usb1: Product: DWC OTG Controller
[ 1.349102] usb usb1: Manufacturer: Linux 3.18.5-v7 dwc_otg_hcd
[ 1.349117] usb usb1: SerialNumber: bcm2708_usb
[ 1.350119] hub 1-0:1.0: USB hub found
[ 1.350184] hub 1-0:1.0: 1 port detected
[ 1.350750] dwc_otg: FIQ enabled
[ 1.350763] dwc_otg: NAK holdoff enabled
[ 1.350773] dwc_otg: FIQ split-transaction FSM enabled
[ 1.350825] Module dwc_common_port init
[ 1.351318] mousedev: PS/2 mouse device common for all mice
[ 1.352397] usbcore: registered new interface driver iforce
[ 1.353842] Bluetooth: Virtual HCI driver ver 1.5
[ 1.354023] Bluetooth: HCI UART driver ver 2.2
[ 1.354040] Bluetooth: HCI H4 protocol initialized
[ 1.354051] Bluetooth: HCI BCSP protocol initialized
[ 1.354061] Bluetooth: HCILL protocol initialized
[ 1.354072] Bluetooth: HCIATH3K protocol initialized
[ 1.354083] Bluetooth: HCI Three-wire UART (H5) protocol initialized
[ 1.354213] usbcore: registered new interface driver bcm203x
[ 1.354334] usbcore: registered new interface driver bpa10x
[ 1.354468] usbcore: registered new interface driver bfusb
[ 1.354595] usbcore: registered new interface driver btusb
[ 1.354618] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[ 1.354803] usbcore: registered new interface driver ath3k
[ 1.355116] bcm2835-cpufreq: min=600000 max=900000
[ 1.368662] sdhci: Secure Digital Host Controller Interface driver
[ 1.368671] sdhci: Copyright(c) Pierre Ossman
[ 1.368802] DMA channels allocated for the MMC driver
[ 1.407151] Load BCM2835 MMC driver
[ 1.407381] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.408723] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.408839] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.412441] usbcore: registered new interface driver usbhid
[ 1.412450] usbhid: USB HID core driver
[ 1.412891] TCP: cubic registered
[ 1.412908] Initializing XFRM netlink socket
[ 1.412935] NET: Registered protocol family 17
[ 1.413140] Bluetooth: RFCOMM TTY layer initialized
[ 1.413164] Bluetooth: RFCOMM socket layer initialized
[ 1.413188] Bluetooth: RFCOMM ver 1.11
[ 1.413211] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.413229] Bluetooth: HIDP socket layer initialized
[ 1.418064] sctp: Hash tables configured (established 16384 bind 16384)
[ 1.420632] Key type dns_resolver registered
[ 1.424302] Registering SWP/SWPB emulation handler
[ 1.425044] registered taskstats version 1
[ 1.425283] vc-sm: Videocore shared memory driver
[ 1.425300] [vc_sm_connected_init]: start
[ 1.425829] [vc_sm_connected_init]: end - returning 0
[ 1.428050] ALSA device list:
[ 1.428064] #0: bcm2835 ALSA
[ 1.428579] Waiting for root device /dev/mmcblk0p6...
[ 1.444503] mmc0: host does not support reading read-only switch, assuming wr ite-enable
[ 1.446599] mmc0: new high speed SDHC card at address 59b4
[ 1.447077] mmcblk0: mmc0:59b4 NCard 15.0 GiB
[ 1.450761] mmcblk0: p1 p2 < p5 p6 p7 > p3
[ 1.538177] EXT4-fs (mmcblk0p6): couldn't mount as ext3 due to feature incomp atibilities
[ 1.538763] EXT4-fs (mmcblk0p6): couldn't mount as ext2 due to feature incomp atibilities
[ 1.547259] Indeed it is in host mode hprt0 = 00021501
[ 1.628510] EXT4-fs (mmcblk0p6): mounted filesystem with ordered data mode. O pts: (null)
[ 1.628565] VFS: Mounted root (ext4 filesystem) on device 179:6.
[ 1.636091] devtmpfs: mounted
[ 1.636632] Freeing unused kernel memory: 464K (80926000 - 8099a000)
[ 1.727212] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.727342] Indeed it is in host mode hprt0 = 00001101
[ 1.773064] EXT4-fs (mmcblk0p6): re-mounted. Opts: data=ordered
[ 1.797181] FAT-fs (mmcblk0p7): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 1.800363] FAT-fs (mmcblk0p5): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 1.927446] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.927474] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.928246] hub 1-1:1.0: USB hub found
[ 1.928360] hub 1-1:1.0: 5 ports detected
[ 2.191424] udevd[86]: starting version 2.1.1
[ 2.206705] random: udevd urandom read with 68 bits of entropy available
[ 2.207296] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.307668] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.307692] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber =0
[ 2.310686] smsc95xx v1.0.4
[ 2.371448] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1 .1, smsc95xx USB 2.0 Ethernet, b8:27:eb:4d:ee:7e
[ 2.877215] usb 1-1.3: new full-speed USB device number 4 using dwc_otg
[ 3.845076] random: nonblocking pool is initialized
[ 3.894228] usb 1-1.3: New USB device found, idVendor=0a12, idProduct=0001
[ 3.894258] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber =0
[ 3.894269] usb 1-1.3: Product: BT2.0
[ 4.137378] usb 1-1.2: new high-speed USB device number 5 using dwc_otg
[ 4.197694] input: Genesis 6 pad as /devices/virtual/input/input0
[ 4.200105] PORT1 configured for Genesis 6 pad
[ 4.258152] usb 1-1.2: New USB device found, idVendor=0cf3, idProduct=9271
[ 4.258175] usb 1-1.2: New USB device strings: Mfr=16, Product=32, SerialNumb er=48
[ 4.258186] usb 1-1.2: Product: USB2.0 WLAN
[ 4.258196] usb 1-1.2: Manufacturer: ATHEROS
[ 4.258207] usb 1-1.2: SerialNumber: 12345
[ 4.322138] usb 1-1.2: ath9k_htc: Firmware htc_9271.fw requested
[ 4.323209] usbcore: registered new interface driver ath9k_htc
[ 4.612267] usb 1-1.2: ath9k_htc: Transferred FW: htc_9271.fw, size: 51272
[ 4.857290] ath9k_htc 1-1.2:1.0: ath9k_htc: HTC initialized with 33 credits
[ 5.286485] ath9k_htc 1-1.2:1.0: ath9k_htc: FW Version: 1.3
[ 5.286510] ath: EEPROM regdomain: 0x809c
[ 5.286518] ath: EEPROM indicates we should expect a country code
[ 5.286528] ath: doing EEPROM country->regdmn map search
[ 5.286535] ath: country maps to regdmn code: 0x52
[ 5.286544] ath: Country alpha2 being used: CN
[ 5.286551] ath: Regpair used: 0x52
[ 5.297261] ieee80211 phy0: Atheros AR9271 Rev:1
[ 5.301128] cfg80211: Calling CRDA to update world regulatory domain
[ 6.920649] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 18.878906] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0x4DE
DigitalLumberjack wrote:Yep and ifconfig -a please
# ifconfig -a
eth0 Link encap:Ethernet HWaddr B8:27:EB:4D:EE:7E
inet addr:192.168.0.109 Bcast:192.168.0.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:87 errors:0 dropped:0 overruns:0 frame:0
TX packets:76 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:9928 (9.6 KiB) TX bytes:10256 (10.0 KiB)
lo Link encap:Local Loopback
LOOPBACK MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
wlan0 Link encap:Ethernet HWaddr 64:70:02:23:2F:4A
UP BROADCAST MULTICAST MTU:1500 Metric:1
Scrub that, found itgeppetto wrote:I have Connected to recalbox via Putty.
Where do I find the recalbox.conf file please?
Phil
So it is supported.DigitalLumberjack: Pls Support TP-Link TL-WN722N USB wireless adapter
yes remove.DigitalLumberjack wrote:So it is supported.DigitalLumberjack: Pls Support TP-Link TL-WN722N USB wireless adapter
Did you set in recalbox.conf the ssid and the key ? Removed the ; in top of the line
Yep only wpa...OH650R wrote:I'm still not able to connect via wifi with the realtek adapter. My security setting is WEP if that matters? I only mention it because I use to have a Nintendo DS that would not connect to a WEP secured network and worked fine when I would switch to WPA.
99% time the up and down are the same axis, with + and - values.OH650R wrote:Also, there is JOYSTICK UP and JOYSTICK LEFT in the controller config, but no DOWN or RIGHT?
DigitalLumberjack wrote:In order to edit config.txt file, plug a keyboard and let Shift pressed at startup, then "e" and edit the file from here.terminator2k2 wrote:hi there, im trying to get my monitor up and running which uses dvi.
this was my config:
disable_overscan=1
hdmi_group=2
config_hdmi_boost=4
#sdtv_mode=2
# Overclock
gpu_mem=512
avoid_safe_mode=1
kernel=zImage
hdmi_drive=2
hdmi_safe=1
Remove all hdmi_* from the file and save and escape to boot.
